Yet another winterizing question - Page 4 - Fiberglass RV
Old 11-20-2013, 08:19 PM   #43
carlkeigley's Avatar
NE Oklahoma
I'm learning...........
Old 11-20-2013, 08:31 PM   #44
Trailer: Fiber Stream
Thumbs up The Pink Stuff (Propylene Glycol) is non-toxic
Originally Posted by steve dunham View Post
... confused with RV anti freeze (propylene glycol) which is non toxic. I worked at a vegetable oil refining plant and I believe we processed soybeans to make glycol for use in latex paints and RV anti freeze and toxicity was not a major issue
I maintain the scales at the edge of the marine mammal pools at Sea World San Diego that the Orcas and Dolphins are trained to leap out of the water and land on, thus weighing themselves in the presence of the trainers and veterinarians much in the same way that humans do at their doctors' offices.
The pools that these animals live in are filled with 55 degree Fahrenheit salt water. The scales are electronic, yet must function in this environment. What one company has designed is an intermediate hydro-static pressure sensor system to place the electronic components remote from the cold salt water, while being connected through the digital-to-hydrostatic transfer module to the platform the animals weigh on.
The hydrostatic (or hydraulic) fluid must be:
  • High viscosity to flow without loss of pressure transfer at low temperature
  • non-toxic so leakage does not harm the animals
The closed-loop fluid chosen is 50% distilled water, 50% propylene glycol, and red food coloring... or in other words diluted RV anti-freeze.
Old 11-20-2013, 08:44 PM   #45
I would suggest that you look up Propylene Glycol. To say it's non-toxic isn't the full story.
Old 11-21-2013, 05:17 AM   #46
Trailer: 1980Trillium 1300
Thanks for the inputs from forum. I was mixed up b/t auto coolant and anti-freeze for trailers, also the toxic of windshield auto fluid. I't's never too late to learn more. With my own Trillium, I don't use anything, just drain water tank, dismantle water pump and leave all caps opened....Thanks again...
Old 11-21-2013, 09:38 AM   #47
Good idea Byron.
Propylene glycol - Wikipedia, the free encyclopedia
Propylene Glycol: The Good, the Bad and the Alternatives
Old 11-21-2013, 11:28 AM   #48
NE Oklahoma
pg is found in a lot of our food labels.......
Old 11-24-2013, 06:15 AM   #49
OneTim's Avatar
Trailer: Escape
Rhode Island
The second article contains junk science: "It's foreign to our body and as such is toxic."
It's OK If someone doesn't want to use propylene glycol. However, safety isn't an issue.
OneTim is offline   Reply With Quote
Old 11-24-2013, 06:33 AM   #50
Pam Garlow's Avatar
Trailer: U-Haul 1985
I only have a hand pump in my camper. Just like Thinh, I don't use any antifreeze. I empty the water tank and pump the hand-pump until it is pulling only air
Since I don't have a bathroom, grey/black tanks, 12v pump, there's not much else to do.
Winterizing? hobofoto Care and Feeding of Molded Fiberglass Trailers 10 10-27-2013 02:57 PM
13' Scamp / Winterizing Question Sheryl M Care and Feeding of Molded Fiberglass Trailers 4 01-03-2008 08:43 PM
"De"- winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 6 06-05-2003 02:44 PM
Anode Rod winterizing question? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 15 10-18-2002 09:03 PM
Winterizing Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 09-20-2002 09:09 AM
