For Sale: Hunter Compact II - Fiberglass RV
Old 10-08-2019, 03:51 PM   #1
Trailer: Hunter Compact II
Mississippi
Hunter Compact II
While the specs online say that these weigh about 1100 pounds, the information plate on the outside of the trailer says:
Date: 5 73 May 1973
GVWR: 1570
GAWR front: 1500
Serial C1393
Original dealer sticker: Roy's Cars and Trailers, Ogden Utah.
The title and registration say that it is a 1974 model. It belonged to my late mother, who towed her pride and joy with her 4 cyl Chrysler PT Cruiser on many camping trips. We aren't able to take the time to go camping, so we are looking for a home for it.
All original interior and exterior. The only exceptions are the air conditioning unit that requires hookup, some spots on the kitchen walls where stick on hooks came off over time, the paper towel holder, and metal plates installed to hold curtain rods. Original equipment includes sink with handpump faucet, 3 burner stove that works well, ice box that needs drain tube replaced, clean water tank, also it must have a grey water tank, but I have not found it yet, propane furnace/heater which my mother said worked. Interior lights all but one works, may just be a burned out bulb. All cabinets and drawers are original and work and include a pantry, a closet, and multiple drawers and hatches, plus storage under the seat cushions. Seat cushions convert to a bed, as per normal. All windows work, screens are in good condition. NO LEAKS. The quilted naugahyde ceiling and walls are in perfect condition, the original linoleum floor is in very good condition, the cushions are in very good condition I would say the material is starting to feel a little brittle, but lots of wear left in them, no tears or open seams and the foam is still comfy . Original wallpaper in the closet/potty room very clean. No potty is included, my mother used a bucket toilet.
I have not opened the pop up top. My mother was short enough she used the trailer without it, and I'm worried that the material will either tear with opening or already has tears; however, the pop top absolutely DOES NOT LEAK as it is currently, and I know the mechanism works fine. I understand that it's generally expected that these will have to be replaced. There are 2 spots where the exterior fiberglass got dinged, very much on the surface, no water leakage at all. There is a rock pockmark in one window, and the frame of that window has a little bent piece will bend back . Potable water intake is missing the cap. External vent in kitchen needs replacing. There is some surface rust on the frame if I were keeping it I would apply rust converter to the whole frame, you don't sand the rust you leave the rust in place so it converts to a black enamel like surface. Any rust is very light, only the surface, the frame is in excellent condition for the age. Tires are good, spare tire is good. Has propane bottle. One interior light doesn't work, may just need bulb. The floor is solid.
One exterior running light cover is missing, there is a replacement in a drawer inside. The door is tweaked, it got sprung open in a wind storm, cracked a window, and it doesn't seal completely. My mother used window sticky foam strips to close the opening. We have kept a fan running in the trailer the whole time it's been here, so it DOES NOT smell musty and there is no mold. I strongly suggest keeping a fan running in your trailer, makes a huge difference in keeping it fresh.
I have the original owner's manual somewhere but I put it away "to keep it safe" and now can't find it. Will make a big effort to find for buyer. My mother made curtains for it, and it also comes with some vintage kitchen ware a set of matching dishes with some silverware, a metal drip coffee pot, and a kettle for boiling water.
Please contact me if you have any questions.
Thank you.
View this ad at Fiberglass Classifieds - Hunter Compact II
VictoriaNOLA is offline   Reply With Quote
1973 Compact II by Hunter Darrel Smith Modifications, Alterations and Updates 87 04-05-2019 04:18 PM
Hunter Compact II Owners Legacy Posts Care and Feeding of Molded Fiberglass Trailers 41 06-14-2016 10:08 AM
Compact and Hunter history Tom Trostel General Chat 57 10-19-2012 12:36 PM
Hunter 1 (Compact II ?) Legacy Posts Care and Feeding of Molded Fiberglass Trailers 24 05-13-2003 09:14 PM
1975 Hunter Compact Classified Archives 0 01-01-1970 12:00 AM
