Spring is just around the corner and it s time to get your trailer ready, at Camping Treasures we have the best parts you can get for your
boler. click on the bold
title to link to our store All parts available through www [dot] CampingTreasures [dot] com
DOOR HINGE REPAIR KIT, No need to replace your hinges, rebuild them and they will be better than new. If the door hinges on your
Boler or
Scamp trailer worn out or if the bolt or spring are broken or rusted our Stainless Steel Door Hinge Repair Kit is the solution
These kits contain the highest quality parts at a reasonable price that won t rust and will last for many years?
The kit includes everything you will need to rebuild both hinges, one kit is all you need for your trailer:
2 solid brass pivot balls made in USA
2 316 stainless steel bolts
2 316 stainless steel nylock nuts
2 316 stainless steel springs made in Canada
4 nylon isolation washers
Synthetic Teflon assembly lube
DOOR LOCK REPLACEMENT KIT for 1975 1988 boler's. Our door lock kit is designed to replace the discontinued Bargman L400 and Lyster 20 213 / 20 214 door locks found on many vintage trailers
Using common tools the average DIY er can replace their door lock with a modern Bauer lockset with deadbolt.
Our complete kit includes:
1 Bauer Door lock, packaged available in White or Chrome
1 Inner Aluminum Adapter Plate
1 Outer Aluminum Adapter Plate
1 Aluminum Striker Plate
2 8 32x Pan Head Machine Screws
4 8 32x Pan Head Machine Screws
4 8 32 1 Pan Head Machine Screws
2 10 24x Flat Head Machine Screws
2 10 Flat Washers
2 10 24 Nuts
6 Aluminum Rivets
1 roll Butyl Sealing Tape
1 corner drill guide
1 pair Disposable Gloves
1 Dust Mask
JALOUSIE WINDOW OPERATOR Worn or broken Jalousie Window Torque Rod Operator can result in
windows that don t close completely, are hard to open, won t open at all, or flap in the wind while driving. Although several different styles of operators were used on
boler s this one is very common. They fit both dinette
windows on most boler s with the sloping lower sill, but also fits many other trailers manufactured in the 1970 s
Buy now while supplies last. These operators have been very hard to find, but we had the manufacturer custom make us a supply, we recommend that if you need them don t wait.
Specifications:
1/2 Inch inner diameter hole
11/16 Inch hub projection
Fit both
windows where the operator is located on the bottom right side
WINDOW GRAVEL GUARD HARDWARE in Stainless Steel Camping Treasures now offers high quality stainless steel hangers and latches.
Our Stainless Steel Hardware kit includes:
2 Stainless steel latches with an integrated safety catch that prevents accidental opening made in in the UK
2 Stainless steel hangers that are easy to use and very strong
We recommend you also purchase our optional rivet kit is made from high quality, aircraft grade, full stainless steel rivets even the pin is stainless steel and stainless steel backing washers and includes:
8 5/32 stainless steel pop rivets w/ stainless steel pins
8 5/32 stainless steel pop rivet backing washers
8 3/16 stainless steel pop rivets w/ stainless steel pins
8 3/16 stainless steel pop rivet backing washers
NOTE: You will need a heavy duty or long handle rivet gun to install the 3/16 rivets, a standard rivet gun will not set the mandrel.
View this ad at Fiberglass Classifieds -
NEW BOLER HARDWARE boler Repair Parts
