-   -   Help the confused mod!!!! (http://www.fiberglassrv.com/forums/f55/help-the-confused-mod-25046.html)
Gina D. 04-02-2006 06:54 PM
I am looking for the thread with the little point of use hot water heater someone installed.
I want to put a couple in my home and need to see how he connected it!
I am stumped.
Chris B 04-02-2006 07:07 PM
http://www.fiberglassrv.com/board/index.ph...3260&hl=instant
Is this it?
Lee Hillsgrove 04-02-2006 07:17 PM
Lance MacArthur's Blue Boler slide show has detailed photos of a point-of-use hot water dispenser.
Gina D. 04-02-2006 07:25 PM
http://www.fiberglassrv.com/board/st...default/52.gif
Thanks, but this thread was specifically about the little heater and it's install.
Brian B-P 04-02-2006 07:34 PM
In Con's Boler Mods. thread, he had one post in which mentioned the Instant Hot Water Heater installation and provided PDF documents... but that's certainly not a dedicated topic. These heaters were also mentioned in two recent topics about the Coleman Hot Water On Demand, but without real installation information.
As shown in the Blue Boler pics, I think the water source for these heaters is usually a clamp-on tee fitting.
Con 04-02-2006 09:56 PM
Gina,
If you check my pics on Webshots and on my thread, also I sent the info on the Insinkerator hot water dispenser to Donna for the Helpful Links page. I used the smallest unit because of its compact size and it produces something like a gallon and a half of hot water and hour. They make many different sized units and if I had a 16' trailer I would probably have installed a bigger unit.
We found it was perfect for making soup, a cup of instant coffee, washing your hands or dishes with out having a big tank or using the water from our 10 gallon tank. I cut a tee into the city water feed, one to the hot water heater and the other to the right hand tap. That gives us our hot/cold water. The on board 10 gal. tank feeds to the diaphram pump which supplies the left hand tap. That is strictly cold water.
I suppose the sytem could be set up to run off a invertor/convertor setup if someone wanted to have it as a stand alone system. Our Boler dosn't have either of those so I optted to do it as mentioned.
The only thing is it is 110v and is hooked up to city water. That can of coarse be a draw back if you want a stand alone system for when you are boondocking.
So far I have been very pleased with it.
Last summer I found one little leak at one of my connectors but that is no big deal to fix.
Does that answer your question?
Gina D. 04-02-2006 10:38 PM
Thats not what I am looking for either http://www.fiberglassrv.com/board/st...ult/helpme.gif
It is a small tankless point of use heater similar to this:
Point of use instant hot water
This isn't the one I was trying to find, but it's the same idea, a little more for home use.
And this it's what it's for, my unrolling home. It's time to replace my big ole gas guzzlin' heater which will involve some contruction. I firgured these would be.. cheaper, and gooder for a single person household.
Con 04-02-2006 11:06 PM
Ahhh Soooo! Now I understand! Very similular concept though.
They use a lot of those type of units in England & Europe. Years ago a friend of mine was trying to get import licences to bring a on demand shower gizmo from England. It was a very neat modern unit. The red tape they threw in his way was so fierce that he gave up. To this day I still don't see them in this country!
CD Smith 04-03-2006 06:54 AM
I bought the one I have from Sears. It provided enough hot water to make tea/instant coffee, wash your hands, and wash dishes, but not enough for shower.
The only problem with it was the water in the unit would evaporate and when you turned the hot water faucet on all you got was steam.
Brian B-P 04-03-2006 12:24 PM
...It is a small tankless point of use heater similar to this:
Ah, a full-fledged demand-type heater, not just a beverage water dispenser. That's a lot of electrical demand, but I guess that's okay if you have a spare circuit space in your distribution panel, and are not right up against the total house electrical capacity. Don't laugh - I had a house with 60-amp service, just a tiny bit more than many RVs.
No little clamp-on tee fitting for this setup - I assume you would plumb it in exactly as the current tank-type heater.
I'm sure it would be cheaper than any gas-fired heater, as it is dead simple. As a tankless unit, it would also be small and light - although those things don't matter in a house.
Any electrical water heater makes no sense to me in a house with natural gas service and a convenient way to vent exhaust. Electricity is just very expensive energy, and it is spectacularly inefficient to burn fossil fuels to make heat to form steam to run turbines to turn generators to make power to transmit to a house... to make heat again.
Gina, are you sure you weren't thinking of a gas-fired (propane-fired) tankless heater thread? That's been discussed, too. A tankless gas-fired heater saves the energy consumption of keeping a big tank of water hot, so it has the same advantage as an electric demand water heater.
Gina D. 04-03-2006 09:42 PM
I want electric ones. You haven't seen the natural gas prices here recently. I have taken to heating my house with ceramic heaters because it's CHEAPER than gas is now.
I also grew up in hydro electric land (Oregon). No fossil fuel burning to turn turbines.. a big old river does it ah natural.
Electric has been spotty, up and down here for a lot of years, but since I am a household of one, it's actually pretty cheap for me.
What isn't cheap is a constant flame under a 40 gallon tank that stays heated all day and nite when I only use the product in the am and evenings.
I was clothes in cold, with very rare exception.
The littler tanks like I am looking for SHOULD be an easy install with compression fittings, but I wanted to see the close ups of the one in the thread (it was electric, btw) before I made a final decision.
For some reason, Lowes and home depot make you order these things, none on the shelf. I don't like that.
Elsie G. 04-03-2006 10:16 PM
Hi Gina, just read your post and thought I'd throw in my 2 cents. We have an electric water heater that has a timer on it, it only heats up twice a day. AM for Renee, PM for me. We bought the smallest one we thought would meet our needs.... and it does!
Lizbeth 04-03-2006 10:17 PM
We have a gas on demand heater so that's no help other than to say we love it.
I'm loosing my mind too......I was hunting a thread that showed a shelf/counter extension toward the front of the trailer. I found Colin's but that's not the one. On with the hunt....
Lynn Musgrave 04-03-2006 11:04 PM
Hi Gina ......I have heard (from a friend that works there) that Home Depot has this type of system...most of their stores only stock one at a time ,but will order them for you. Now I never ask if the are gas or electric,but that would be a place to start your search. I have used this type system in Belgum and it is Great..........it might cost a lot to get it installed ( because of special venting needed) but in the long run I think it would be worth it. My parents used electric Hot water heater...............with one of those water heater blankets on it and a timer for years. They were pleased with that and always had enough hot water for what little they needed during the day and then the timer clicked on in time for baths.
Hope this helps.........Lynn
