-   -   Trillium Frame Concerns; Repair Update (http://www.fiberglassrv.com/forums/f55/trillium-frame-concerns-repair-update-25428.html)
Joseph Olajos 04-28-2006 07:07 PM
Following up on advice gleaned from forum readers, I had the frame reinforced on our '73 Trillium today. Side plates (gussets) consisting of 2"x 16" diamond-shaped 1/8" steel were welded to both sides of each front section of the A-frame in an area from about 4" behind the f/g shell anchoring bolts to about where the frame is "dimpled" from the factory bending process.The work was done at a custom welding/fabricating shop here in Peterborough; 2 hours of labour and material, the bill came to $161.00, taxes incl.... as well, they installed two new anchor bolts, and painted the areas of the welds...especially between the frame-top surface and f/g shell, since they had to raise the shell somewhat to prevent heat damage while welding the top edges of the gussets. At my request, they also did a once-over insp'n of the entire frame(while up on the hoist),and declared it to be still in excellant shape and quite sound.
A profesional job, to be sure, and at a fair price; can't beat that !
Joe
Doug Mager 04-28-2006 09:06 PM
Sounds ALMOST Egg-zakerly what Reace at Escape Trailers did for us in the line of updates when our Trillium was in his plant!!! http://www.fiberglassrv.com/board/st...default/78.gif
old yeller 03-08-2015 08:48 AM
hi we have a 76 13ft trillium that is honeycombing on the front.does anyone know a good fiberglass shop in on. thanks old yeller
Mom2philip 03-08-2015 12:44 PM
When you have a chance can you take some pictures? I think we might need to do that as well.
