-   -   Trillium 1300 Cushion sizes (http://www.fiberglassrv.com/forums/f55/trillium-1300-cushion-sizes-27261.html)
brendadave 10-24-2006 10:42 AM
Hi all, we recently purchased a 1976 Trillium 1300, it is in great shape, but we would like to change the upholstery.
The problem is that one of the previous owners changed the foam and upholstery in the rear dinette and pieces donít fit into the space correctly. When they cut the new foam they had only one piece over the table rather than two, this makes it difficult when you want to put the table up because it is hard to find a place to put the big piece of foam.
Would anyone who has replaced their foam/upholstery before (and I can see from other posts many of you have), be able to provide us with the correct measurements, or at least some good pictures so we can figure out how they are supposed to fit.
Thank you very much.
TomA 10-25-2006 07:40 PM
The solution is easy if the cushions fit properly when made up as a bed.
Simply cut the large peice that covers the table in half. They now become the back rest for the seats. This is how the original design was & is.
For further help/fabric, call Outback Trailers in Calgary. 403: 398-8732
They probably have a comeplete set in stock.
Tom Young
TrilliumRV.com
brendadave 10-26-2006 06:30 AM
Tom Young
TrilliumRV.com
That is the problem, they don't fit properly, the one on the table sticks about 8 inches past the end of the table, the two side cushions I think are too small as they move around and there are big gaps on all sides.
Thanks for the suggestion though, we will give them a call.
