-   -   Goodyear Marathon tires (http://www.fiberglassrv.com/forums/f55/goodyear-marathon-tires-27410.html)
Dan Quinn 11-12-2006 09:52 PM
THE GOODYEAR TIRE & RUBBER COMPANY
PRODUCT SERVICE DEPARTMENT
Page 1 of 2
Product Service Bulletin
Important Information To Better Service Your Customers
Post For Ready Reference
March 6, 2006
PSB #2006-06
TO: Goodyear Company Owned Outlets
Goodyear Contract Dealers
Subject: Marathon Special Trailer Applications - General Information
Goodyear Marathon tires are widely used in a variety of towable trailer
applications and are designed and
branded as “ST” (Special Trailer) tires.
This bulletin is designed to help you obtain the best performance from tires
with the ST (Special Trailer)
designation. Please review the following important points with your Goodyear
Marathon customers.
• Industry standards dictate that tires with the ST designation are speed
restricted to 65 MPH under
normal inflation and load conditions unless a different speed restriction is
indicated on the sidewall of
the tire.
• Based on industry standards, if tires with the ST designation are used at
speeds between 66 and 75 mph,
it is necessary to increase the cold inflation pressures by 10 psi above the
recommended pressure for the
load.
o Do not exceed the maximum pressure for the wheel.
o If the maximum pressure for the wheel prohibits the increase of air pressure,
then the
maximum speed must be restricted to 65 mph.
o The cold inflation pressure must not exceed 10 psi beyond the inflation
specified for the
maximum load of the tire.
• Drivers should always obey posted speed limits and reduce speeds when
necessary based on vehicle,
road, weather or traffic conditions.
• Trailers tires should be operated at inflation pressures that are specified by
the trailer manufacturer.
The trailer manufacturer’s inflation information can usually be found in the
owner’s manual, tire
information placard or vehicle certification label, usually located on the
forward left side of the trailer.
• Cold inflation pressures should be checked every morning during trips and
monthly while in storage.
Page 2 of 2
• Vehicles or trailers should not be overloaded. The tire information placard,
vehicle certification labels or
owner’s manual should be checked for the maximum recommended load.
Vehicle speed, load and inflation pressures, all of which are within control of
the driver, are critical factors
for the safe and enjoyable operation of any vehicle.
Important tire care information and the load / inflation tables are available on
Goodyear’s Recreational
Vehicle web site at www.goodyear.com/rv, or by ordering the Recreational Vehicle
Tire and Care Guide,
product code 700-862-911-55600.
