-   -   What to paint the foam on the roof with? (http://www.fiberglassrv.com/forums/f55/what-to-paint-the-foam-on-the-roof-with-34860.html)
sarah j 08-24-2008 01:44 PM
Is that what is called "ensolite"? We are wanting to repaint the foam/insulation on the roof of our Boler. Should we use a base coat of "Kilz" first since there is some old mildew issue? And after that should we sue a bathroom paint or?...
Jason, M 08-24-2008 01:48 PM
sarah,
I just painted my ensolite. A good primer and then a kitchen bath paint that is anti-mildew. It's easy.
Chester Taje 08-24-2008 02:20 PM
3 Attachment(s)
I used melimane paint on my insolite when i had my 17ft Boler. I cleaned as best as i could. It turned out real nice. As you can see i painted everything.
sarah j 08-24-2008 03:06 PM
Did you use a brush or roller to paint it?
And you use the same paint on the walls and cupboards?
Thanks again!
Chester Taje 08-24-2008 03:16 PM
Thanks again!
I used a foam roller and a brush for the tight corner areas. The wood i lightly sanded first. Same paint for everything.
Jason, M 08-24-2008 04:22 PM
I used a regular roller, but a shorter version. I did not sand the cabinetry, just primed it. Same paint all over.
