-   Plumbing | Systems and Fixtures (http://www.fiberglassrv.com/forums/f96/)
-   -   Exterior Shower (http://www.fiberglassrv.com/forums/f96/exterior-shower-39406.html)
Matthew A 08-19-2009 03:43 PM
I have a new to me scamp trailer, very excited. It is a 2002 16ft model. I want to add an exterior shower because the toilet/shower area is a little small for showering.
Has anyone added an aux. shower to there unit? Are there places you can and cannot cut into the scamp to mount the aux shower (requires about a 8" x 12" hole). I was thinking of putting it so it pokes into the cabinet that the water tank is housed in. There seems to be plenty of room for the intrusion, just not sure if I can make a hole there.
What do you think?
Also thank you so much for this wonderful site, I was able to get very well educated before I took the plunge.
Jim Bennett 08-19-2009 04:03 PM
Matthew, I would see no problem putting it almost anywhere, though I am not familiar with the Scamp. The back of any cabinet you can easily access for hooking up, or maintenance should work. A hole that small should not compromise the integrity of the shell at all.
Chester Taje 08-19-2009 04:09 PM
I agree with Jim.
Donna D. 08-19-2009 06:10 PM
Essentially what you're doing is cutting a hole like you'd do if you were putting in a hatch. You may want to check out peterh's excellent topic on the hatch he put in his Scamp, it should give you some pointers:
Adding a hatch
Jim Bennett 08-19-2009 06:25 PM
I agree with Jim.
I wish I could just get my wife to do this. ;)
Carl O 08-19-2009 10:02 PM
Personally, if I were thinking of showering outside of the trailer, I would look at something like this: http://www.zodi.com/web-content/Consumer/z...avelshower.html
My 2 cents.
-Carl
Jim Bennett 08-19-2009 11:28 PM
Carl, those would be nice, but if you already have a hot water heater, the bulk of carrying it would be nice. I bet it is great for tenters though.
Matthew A 08-20-2009 01:16 PM
Thanks for all of the help I think I will go ahead and add my shower, I will let you know how things work out.
Robert Johans 08-20-2009 06:18 PM
I'm in the process of a complete overhaul to my 13' Scamp. Many upgrades, not the least of which is an outdoor shower.
When at most RV parks, it occurred to me that the curbside/entry-side is most "private" side, so I located my shower there, just below my "porch" light. This location is on outside of the vertical cabinet inside, so the plumbing is hidden within the cabinet. I'm customizing the interior of the vertical cabinet so that I can have access to all the plumbing, while adding more efficient storage.
Obviously, the shower required cutting a hole into the shell. No big deal, IF you take MUCH care with your measuring and your cutting. I had no serious problems and the results are great.
Good luck.
John Hussey 08-21-2009 05:05 AM
Outside shower, CHEAP:
http://www.amazon.com/gp/product/B001F1ZPO...7HAMDWBCAQRA193
I have the above. Takes about 3 hours for 2.5 gallons and enough for two navy showers. Of course, one has to anticipate it's use since it takes time to heat but it is WAAAY CHEAP!
Matthew A 08-21-2009 11:13 AM
For privacy I have the Outback Porta-Privy, a great shower tent that takes about 30 seconds to set up and just a few seconds longer to put away. Folds up to a 24" circle that is about 2" thick for super easy storage. I figure a much better option then trying to squeeze into my Scamp shower.
http://www.evergreen-outdoors.net/ou...orta_privy.htm
