-   Care and Feeding of Molded Fiberglass Trailers (http://www.fiberglassrv.com/forums/f54/)
-   -   How to clean rust spots on stainless steel stove cover and oven door (http://www.fiberglassrv.com/forums/f54/how-to-clean-rust-spots-on-stainless-steel-stove-cover-and-oven-door-39679.html)
LeeAnne 09-07-2009 09:17 PM
Any one have any tried and true methods on how to remove the rust on stainless steel stove cover and rust spots on the stainless steel oven door.
Not wanting to paint at this point but is there anything that works???
Alf S. 09-08-2009 06:26 AM
1 Attachment(s)
Hi: LeeAnne... Two names come to mind from our Boler cleaning. AUTOSOL comes in a tube and also NEVR-DULL comes in a can. Avail. [at] Cdn. Tire I think. Both will brighten up your metal surfaces but if they are pitted the rust will reappear next year!!!
Alf S. North shore of Lake Erie :wave
Raya 09-08-2009 06:52 AM
2 Attachment(s)
I like Simichrome or 3M Marine Metal Restorer and Polish.
If the rust doesn't come off with a polish (it probably will), then you can start with something a little bit more abrasive and work your way back smoother (very fine wetsanding paper, a 3M pad, etc.).
Attachment 23262
Attachment 23261
Like Alf said, it's important to have as smooth a surface as possible. The more you keep it smooth and polished, the better it will stay shiny and non-rusty.
Donna D. 09-08-2009 07:23 AM
Stainless certainly doesn't mean rustless as a bunch of us have found out. I use ZUD in my stainless steel sink. It's a non-abrasive cleaner. You can find ZUD in nearly any grocery store with the Comet-type cleansers. But, the rust will come back when any moisture is about. However, ZUD is easy enough to use, I don't mind the upkeep.
YMMV
LeeAnne 09-08-2009 08:53 PM
Attachment 23262
Attachment 23261
Where would I find the 3m Marine Metal Restorer and Polish?????
Raya 09-08-2009 10:33 PM
I imagine that many places must carry it; I would probably order it from Jamestown Distributors.
http://www.jamestowndistributors.com/userp...d=3892&BASE
That said, I see you are in Canada... let me have a look...
Okay, I'm not familiar with which places are near you, or that you might typically mail order from, but here's a link to a Google Canada page with results:
http://tinyurl.com/l6cggx
Raya
james kent 09-12-2009 06:41 AM
Originally, ours was in deplorable condition and I sprayed it with oven cleaner and used a scotchbrite pad to get rid of the grunge and the rust. Now I only have to use a BRASS detailing brush every few years and a bit of metal polish to brighten it up and remove those small rust spots that you just can't get to go away. I just re did it last week and it looks great.
Ed D 09-12-2009 07:09 AM
I've had a real good luck with BAR KEEPERS FRIEND. Here in the States its readily avialable at the dollar type stores and grocery stores. It is relatively inexpensive. I've used it on stainless, plastic and fiberglass.
Ed D
