-   -   Sliding Front and Back Windows (http://www.fiberglassrv.com/forums/f55/sliding-front-and-back-windows-47813.html)
Tom Porter 08-11-2011 09:11 AM
Iíve seen 13' Scamp campers with sliding rear windows but Iíve havenít seen a sliding front window on a Scamp, is there a reason for that? The curvature of the front and the back of the shell look to be pretty close to the same.
Eddie Longest 08-11-2011 10:20 AM
I have a mid 80's Scamp 16 that came with sliding front and rear windows. In rainy weather I had to travel with a 1/2" piece foam behind the gravel shield to keep the water out when on the road. My Compact II has a top hinged front gravel shield, this works much better in keeping out water on a front opening window.
Eddie
Donna D. 08-11-2011 01:47 PM
Tom, you must have a curved back Scamp. That upper area was changed to a flat back sometime early 1980s and that allows a sliding window. You could always do some fiberglass work and build the area up to put in a sliding window, but other than that.. I don't know how a sliding window would curve to the body... the same goes for the front.
Tom Porter 08-12-2011 08:11 AM
OkayÖthat makes sense. I didnít realize that the back had been changed to flat on the newer models. I was perplexed about the curved back and how a sliding window would work on it.
