-   -   Need help removing a frig in a '77 Trillium 1300 (http://www.fiberglassrv.com/forums/f55/need-help-removing-a-frig-in-a-77-trillium-1300-a-54522.html)
Ted 09-21-2012 08:36 AM
I am in the middle of cleaning & re-modelling my '77 Trillium 1300. I have removed the furnace, sink, stove and am now trying to get the fridge out.
Where do I start? Outside behind the vent covers or inside somewhere.
Thanks for any help
Brad Eltherington 09-21-2012 09:33 AM
I just took one out of a 75, it sat on plywood. There where two lag bolts on the floor at the back and two smaller bolts under the door at the front. I unhooked the gas, and because I want to remember the wiring connection for next year when I put it back in, I cut the wire at the fridge. There were two rivits on the trim that I had to drill out
Ted 09-21-2012 04:57 PM
I found 2 holes in the back of the fridge that could've been used to bolt it down but they were empty. I found 1 screw under the door and removed it. I can't locate where the 2 rivets are that you are referring to. Could you please give me a location on them.
Thanks a lot
Ted 09-22-2012 02:50 PM
I GOT IT ! !
Just had to give it a good tug. I guess if you had been stuck in that hole for 35 years you would be kind of reluctant to move easily.
Thanks guys for the help.
