-   -   Halogen lights not working (http://www.fiberglassrv.com/forums/f55/halogen-lights-not-working-58153.html)
Jim Sinor 05-06-2013 02:38 PM
I have a Bigfoot 25B21FB. It has 3 halogen lights over the 'kitchen/sink' area. They have quit working. I figured out how to remove/check the bulbs on these 'puck' style lights. The bulbs are G4's and seem fine. Next I removed the light switch. To my surprise, there is only one wire going to the switch. I searched the cavity behind the light switch and could not find another wire. Can this be correct? Surely the switch requires two wires. Any ideas are appreciated.
Thanks in advance for any help.
steve dunham 05-06-2013 03:21 PM
If the fixture has a metal back plate (housing- case) they maybe using the case as a conductor similar to some flashlights
Ed Harris 05-06-2013 03:36 PM
It looks like the G4 is a 12vdc lamp?
Are the lights inside a fixture as Steve suggests?
If so I would agree with Steve they are probably just using the case as a Ground and shorting through the switch to complete the circuit?
Sounds odd and cheap to me but that is where I would start looking for the problem.
Jim Sinor 05-06-2013 04:03 PM
The lights are in metal fixtures. Hockey puck style with metal rings. I should be able to see if there is 'juice' to the switch. I'm sure that these are 12V as they used to work with only the battery. If there is juice at the switch then the problem should be between the switch and the first light.
All 3 are not working.
Ed Harris 05-06-2013 04:22 PM
Or between the switch and ground?
Jim Sinor 05-07-2013 09:17 AM
Lights are fixed now!
I found the problem. Only one wire going to the switch did not make any sense. I made a hook from a piece of strong wire and fished around in the cavity. I finally found the loose wire. It was the same color as the existing wire (brown) with blue spade connectors. I connected it to the switch and presto, the lights worked. When I reconnected the spade connector, it only wanted to go on half way. I'm sure that whoever did the initial wiring left it only half way on and after 8 years it finally worked loose.
I taped the two wires together so if one does come loose in the future, it won't disappear into the void like last time. Thanks all for the advice.
