-   -   QUESTIONS on Trillium Ensolite removed. (http://www.fiberglassrv.com/forums/f55/questions-on-trillium-ensolite-removed-58235.html)
x2uol 05-10-2013 03:07 PM
1 Attachment(s)
Hi,
Here is a picture with the Ensolite rip off.
But there's residue of the backing.
The question is "Is there a trick to remove what's left?
Maybe their's a liquid cleaner that will help to do the job.
But witch one ?
Is it a good Idea to put something else under the new ensolite to add insolation?
If so What?
Is there a place in or near Montréal where I can buy ensolite.?
Thanks so much
Lou
Attachment 58924
Francesca Knowles 05-10-2013 03:38 PM
Hi, "I"...
This is no help at all, but I simply have to ask:
Is this the trailer pictured in the thread at this link? If it is...did you tear out all the Ensolite, and if so, may I ask why?
Francesca
x2uol 05-10-2013 03:47 PM
Originally Posted by Francesca Knowles (Post 386174)
Hi, "I"...
Francesca
Yes , I rip it off because it was rip at some places, and their was moisture
behind it.
Willys 05-11-2013 09:14 AM
Acetone does work to remove the residue. Just be carefull as it can wreck the fibrglass
Robin G 05-11-2013 10:23 AM
Why not scrape off/ sand off the big chunks then proceed with new installation?
If I remember correctly Trillium still sells ensolite! Just contact them to purchase it. They should be able to recommend what to use for added insulation as well.
http://www.trilliumtrailers.com/
Or, http://www.trilliumrv.com/
David Tilston 05-14-2013 12:31 PM
behind it.
What do you plan to replace it with?
x2uol 05-14-2013 06:39 PM
I'm still searching . Do you have suggestions?
Instead of plywood replacement around the windows, could it be replace
buy oak or maple ??
Spanke 05-14-2013 06:53 PM
I.
Welcome to the forum.
My suggestion would be to maybe slow down a little bit and do some searches on the forum for Trillium renovations. There is a vast wealth of knowledge contained here.
Good Luck with your renovations! :cheers
Spanke
Eddie Longest 05-14-2013 07:09 PM
Once most of the ensolite is scraped off a twisted wire wheel brush on a 4" or 4.5" grinder is the best to get off the remaining foam residue.
Eddie
Donna D. 05-14-2013 07:52 PM
Ryan just completed the ensolite replacement on his Trillium Sportsman and it cost him (with glue) about $1,500. He bought the ensolite from TrilliumRV.
David Tilston 05-15-2013 09:25 AM
Instead of oak, or maple, I think I would replace the frame around the windows with marine plywood. I would also paint it with a good paint.
