-   -   Bargman L300 (http://www.fiberglassrv.com/forums/f55/bargman-l300-58292.html)
theman 05-13-2013 09:22 AM
Bargman L300
1 Attachment(s)
Hello,
I was thinking pf buying a new Trimax lock for my Uhaul but realize that all I needed was this parts ( the inside lock screw) to get my original back together. The thread part is broken of as you can see on the picture.
Does anyone know where or as a spate part he wants to sale!
Thanks for you help!
mary and bob 05-13-2013 11:42 AM
There are repair kits on ebay, not sure what they include. take a look.
theman 05-15-2013 01:00 PM
I have finally decide to order a Trimark unit. I will update as soon as I get the part.
Fred
Thomas G. 05-15-2013 01:06 PM
Also this:
L300 RV Lock Bargman L 300 Replacement Travel Trailer Lock Direct Replacement | eBay
Raz 05-15-2013 02:17 PM
Originally Posted by theman (Post 386970)
Hello,
I have the repair kit. That's included. Isn't it two pieces that screw together? Not sure but I recognize it. Unfortunately the repair kits now cost more than the Trimark. :( Raz
Check the picture here
New Bargman L 300 RV Door Lock Repair Replacement Parts Kit | eBay
mszabo 05-15-2013 04:53 PM
If it is a broken off screw, try to remove it.
If not drill it out and tap it with the screw size needed.
Screw in screw, lock tight it and, cut off screw to length needed.
theman 05-15-2013 05:58 PM
Mazabo,
Thanks for the idea but tubis is wath I kind of did. The key barel cover is also broken. Everything that I need to repair it is in the bargman repair kit listed on ebay but for the same $ I will get a brand new and more solid door lock.
I will receive the new trimark saturday and will give you a update on the fit in the uhaul.
Fred
theman 05-20-2013 07:05 AM
5 Attachment(s)
I just received the Trimark unit. It is a almost perfect fit. To make it a perfect fit I had to grind the right side of the outside box for about 0,5 cm and had to round up the corners. I used a hand grinder for the rough part and a table grinder for the finish. As for the final result I have used rotative sander with 280 sand paper. The resilt os a clean cut and it looks great. Just added some tremglad black paint with a small brush and you dont see the difference.
I had to cut ou a little bit of FG on the door to get the unit in place. Just in the corners of the fitting box. The pen lock fit perficly.
The door now locks great and as a thighter fit . The guide screw just fit perfect in the original female unit.
So as i am concern, this is a great upgrade and find it more relyable than the old L-300.
Here are some pics and if have any question...
Again sorry if my english writting is not perfect!
Fred
Thomas G. 05-20-2013 07:07 AM
Excellent job Frederick. Thanks for posting this.
I think that the price of original L300s just fell on eBay.:loltu
theman 05-20-2013 07:09 AM
140$ shipped to my home for the Trimark. Not to bad :)
rockead rob 09-16-2013 05:40 AM
With the new Trimark latch, were you able to use the original striker plate? I'm about to replace my old, wore out, sloppy Bargman with the Trimark. The previous owner replaced the pins that rest in the striker plate with other bolts that have messed up the threads in the Bargman. Thanks in advance for your response.
mmeyer 09-16-2013 05:48 AM
Fred
Good news, I will update the info for the spreadsheet and submit in October incorporating some other additional info I have assembled since the original submission.
Mi.chael J
mary and bob 09-16-2013 05:53 AM
I met a guy that claims to have a WHOLE CASE of new L300's, [probably a dozen] but he's hanging on to them for his own restoration projects. I can't give out his name. Another guy found a NOS L400 at a RV dealer and got it for $35. Why can't I find this stuff!! However I did get a NOS L300 on ebay for $60 several months ago, that seller didn't do his research.
Thomas G. 09-16-2013 05:56 AM
Some people collect rare coins, others stamps, still others historical items. Then we have the lock aficionados. :D
