-   -   Water Heater (http://www.fiberglassrv.com/forums/f55/water-heater-58301.html)
randybcollins 05-13-2013 04:50 PM
Water Heater
I have an older Coachmen with a newer water heater, propane. My pilot light will light but when I turn it to on nothing happens, my pilot light will stay lit and then go out. The hot water heater may be five years old. This was working last weekend. Any suggestions will be appreciated.
Randy
Joe MacDonald 05-13-2013 05:06 PM
sounds like the thermo-couple that detects the flame isn't getting hot enough to open the main valve, or you have a propane issue. If the propane tank was turned off for a period of time you may have air in you lines which can take time to bleed out while on Pilot
Donna D. 05-13-2013 07:42 PM
Coachman?
papa-t 05-13-2013 08:09 PM
Light the stove burners and let stay on high for a few minuites. Then retry.
mszabo 05-13-2013 09:07 PM
Clean the spider nest out of the burner assembly.
Which will require removing it to do it right.
randybcollins 05-14-2013 05:59 AM
Originally Posted by Donna D. (Post 387135)
Coachman?
English teacher
randybcollins 05-14-2013 06:01 AM
Originally Posted by joe macdonald (Post 387083)
sounds like the thermo-couple that detects the flame isn't getting hot enough to open the main valve, or you have a propane issue. If the propane tank was turned off for a period of time you may have air in you lines which can take time to bleed out while on pilot
thanks, ill see if that helps
randybcollins 05-14-2013 06:02 AM
Originally Posted by mszabo (Post 387183)
clean the spider nest out of the burner assembly.
i did that, it worked last weekend, ill try it again, thanks
