-   -   Hybrid Car as Generator (http://www.fiberglassrv.com/forums/f55/hybrid-car-as-generator-58390.html)
Ken in Philly 05-17-2013 11:55 AM
It's starting to warm up here, and I've been reading all the suggestions about having A/C in the summer. Okay, my 1991 Scamp 16' has an air conditioner. But most state parks here don't have electric hookups, and I'd hate to carry a generator for noise, weight, and bulk.
But wait... I'm towing this with a Prius! It makes an amazing power supply - super efficient (only running when the 220v batteries need refilling) and super quiet. The Scamp A/C seems to draw about 600W when the compressor runs, and 100w with the fan - peak is high but short.
http://www.aprs.org/FD-Prius-Power.html
And they tested it with an electric heater. Lots of detail at:
Prius - UPS Project
I'd like to clamp a 1000W inverter on my Scamp battery terminals, and run an extension cord inside for the A/C. I believe this will draw current from the Prius battery and the Scamp battery simultaneously. I've got the charge line and ground of the 7 way connector wired to my Prius 12V battery. The URL above says the Prius can deliver 100A @ 12V, so I imagine I can get 50 Amps from this line, and let the remainder of what the Prius decides to supply go into the battery as it would anyway.
Is this about to blow anything up? Do I need to connect it directly to the battery? Is this a bad plan overall?
Also: when I can't have the Prius there at all, what will happen if I run the A/C briefly (just to cool it down) off the Deep Cycle battery alone? I've read suggestions to not completely discharge it. What happens if I do?
David Tilston 05-17-2013 12:28 PM
Ken,
You may be able to get 100A from the Prius, but your 7 way connector will not carry that much current. You should either run #2 wires to your trailer, or put an inverter in your Prius and run an extension cord from that to your trailer.
The battery in your scamp would have a maximum of 130 A hrs, it may be half of that. You should not use more then half of that. so 65 A hrs, (or 40 A hrs). At 600W, that would be a minimum of 50 A. So you should be good for about an hour, (or half an hr) of air.
Potential problems:
Starting current on AC is at least double running current, so you require at least a 1500W inverter.
Inverters are not 100% efficient, so it will draw on the order of 10% more then it supplies.
Your battery may not want to supply 50A for an hour. I would monitor the temperature of the battery.
Ken in Philly 05-17-2013 12:47 PM
An hour of A/C should be plenty for cooling the place down. Thanks for confirming my hope there.
I'll put the inverter at the Prius end instead of the camper end, and run the extension cord from there. Makes sense.
Thomas G. 05-17-2013 01:07 PM
I'd suspect that your problems will come from starting the AC on the inverter. You will need a big inverter and may need true sine vs modified sine output. (More $$$). I would also fuse the input from the Prius' DC-DC converter so that you don't accidentally blow that out, as they are very expensive. The Prius 12 volt battery is small, so you might want to add an additional battery next to it, or connect the Scamp battery with very large cables, as has been suggested.
rabbit 05-17-2013 01:27 PM
30k$ generator for "emergency" HVAC? Heart be still!
jack
Thomas G. 05-17-2013 01:37 PM
jack
Be nice Jack. You know that you are a tinkerer at heart. :loltu
Francesca Knowles 05-17-2013 02:03 PM
Are the Prius batteries recharged in this scenario by the gas engine, and if so, how does this differ from any other tug-to-trailer power transfer????
Francesca
Jon Vermilye 05-17-2013 02:12 PM
I've been impressed by the fuel cell developed by Chevy. According to their engineers that attended the New York State Fair a couple of years ago, it was the size of a breadbox & developed 100KW. Now, if you could get it to run on propane, and get the cost under what they were paying ($1,000,000.00 each) that would power your AC and then some!
David Tilston 05-17-2013 04:30 PM
Enough for ~100hp. No more heavy batteries in hybrids. $1,000,000? what is it made of?
Jon Vermilye 05-17-2013 04:47 PM
I don't know, but it is impressive. Biggest problem (other than the cost) is that it requires hydrogen to operate - both finding the stuff & storing it in the vehicle are problems. Still, an incredible amount of power in a small package. I'm sure the carbon in propane would poison the cell & I'm not sure I want a hydrogen based fuel system for a trailer!
Chevy built 100 Equinox SUVs that combined the fuel cell & Nickel Hydride batteries in 2008, but I haven't seem much about the technology lately.
It would make an interesting tow vehicle if the range could be improved. With a 120V tap for the trailer it could supply all the energy needed for everything.
LeonardS 05-17-2013 06:57 PM
Thomas G, don't you tow with a Hybrid? Are you the one that has a battery hookup from the tug to the trailer, tapping into the big battery bank? Or is that someone else?
Just curious, if it is you, did you use a DC/DC converter to lower the voltage before passing it back to the trailer, or did you do the conversion there?
Thomas G. 05-17-2013 07:31 PM
Hybrids use a dc-dc converter in place of a 12volt alternator. So I simply tapped off the 12 volt battery. The dc-dc converter provides about 110 amps at 12 volts in the Escape. I've seen installations where the traction battery is tapped with a 330 volt to 120 volt dc-ac converter to provide much more power. This allows you to use the full power of the generator - about 15,000 watts.
Brian B-P 05-17-2013 08:40 PM
For high power demand (such as for an air conditioner), this makes vastly more sense to me than converting 220 V DC to 12 V DC, and then converting again to 120 V AC... and running about a hundred amps at the 12 V DC stage while pushing the limits of the car's DC-DC converter. This assumes, of course, that one can find an inverter that will run on that input voltage.
The inverter would still be a limiting factor, of course, and 3600 watts might be a sensible size (fully powering a 30 amp RV shore power connection) - no need to handle the whole 15 kW MG1 output.
Thomas G. 05-18-2013 06:50 AM
Right. The conversion I read about was a salvaged industrial inverter. I can't imagine the cost, or even the source of a new one.
Ken in Philly 05-22-2013 09:29 PM
Okay, so I tried it and it failed. It fails on startup of the AC motor. I was all set to send it back when I looked again at the specs: 2400 watts peak.
So... Is there some other problem? The alligator clips don't have a lot of surface connection when they are clipped to the battery leads. Could that be limiting the current? Is the inverter bad?
If its the inverter, what is the best brick and mortar store to visit to try different inverters until I find one that works?
For reference, here is what I had on hand:
http://www.amazon.com/gp/aw/d/B007SL...m_ss2?pi=SY125
Thomas G. 05-23-2013 06:31 AM
BESTEK 1000w 12v to 110v inverter power supply 12v battery backup power charger inverter power solor charger battery boat power motor marine inverter power ac supply emergency power pack outdoor unit power source emergency charger power home applianc
Reference my earlier post repeated here, above. The problem could be that the Prius battery is too small, the cables too small or not making good contact, the inverter surge capacity is bogus, or that the surge current of the AC unit is more than you realize.
Also, this inverter is a modified sine wave, not a true sine, which may also be working against you. You may find some help from the owner's of this site: http://www.donrowe.com/inverters/inverter_faq.html
Do you know how to make some measurements to quantify the start up surge current?
KevinScamps 09-07-2018 12:11 PM
no worky
Probably doesn't startup because of voltage drops from wiring etc. But even if you get it to start it will not actually function well. The Prius has a small charger to keep the 12V battery charged while the main battery has a much more capable converter to push energy into and out of the traction battery. So Prius is really good at charging the 12V battery from the (traction battery) if you have too many lights on and the battery needs charging, but will provide no where near enough power for AC.
widgetwizard 09-07-2018 03:59 PM
Turn the A/C on in the Prius and run a hose back to the Scamp.....
