-   -   What is the proper seal for Scamp window. (http://www.fiberglassrv.com/forums/f55/what-is-the-proper-seal-for-scamp-window-60473.html)
Edox 08-20-2013 07:45 PM
I removed some unsightly caulking around a side window in my Scamp and discover an issue with the window seal. At the top of the window and down a few inches I found some type of glazing material between the outside window frame and the trailer body. The rest of the window had a rubber seal or gasket. I want to put the window back in for a trip we are taking in TWO days. Can I use a butyl tape or silicone caulking to reinstall the window even if it is temporary? Or, is there a readily available rubber tape to replace the one on the window frame.
I hope to get a quick answer if possible. Thanks!
Donna D. 08-20-2013 07:47 PM
Hi Ed, :welcome2: to FiberglassRV, we're glad you're here! :dance
Repeat after me... butyl.... NO silicone on the exterior... ever, ever, ever. :loltu
RogerDat 08-20-2013 09:10 PM
Without a picture not sure what part of the window you are trying to seal. Butyl tape has a huge advantage as a temporary repair.... you can get it off afterwards to do the permanent repair without adding a lot of work to clean off the caulk.
Silicon caulk on a trailer is like a drunken one night stand, easy to get into when your judgment is impaired, embarrassing if anyone finds out. With the potential for long term negative consequences. :eek:
Welcome to the forum.
Edox 08-20-2013 11:58 PM
Lesson learned...NO silicon
The window is now in using butyl. Thanks for the help.:)
Donna D. 08-21-2013 07:11 PM
Ed, you're a quick learner. :yep I hope your window has many years of leak-free service and you won't suffer that dang silly-cone disease :yep
RogerDat 08-21-2013 08:14 PM
Originally Posted by Donna D. (Post 412510)
...and you won't suffer that dang silly-cone disease :yep
The full name of this disease is Silly-cone Trailer Disease, sometimes abbreviated as STD.
