-   -   My Little Project - 1969 Boler (http://www.fiberglassrv.com/forums/f56/my-little-project-1969-boler-65165.html)
sooveroo 07-05-2014 10:09 PM
7 Attachment(s)
Well, I inherited my grandpa's 1969 Boler earlier this year. It hadn't been moved in 15+ years and was in a bit of a state. With the help of a friend and this forum, I managed to get it into working order and although there are far more elaborate renos on this forum, I am pretty proud of this family gem. Here are a few pics. And thanks for all the tips! Never done anything like this before and all the help and expertise was fantastic!
A couple specifics:
1. After looking on this website, we decided to put hull lining directly over my grampy's still functional 70's insulation job. It was a learning process for sure and it is not perfect. We learned that the quality of glue is CRITICAL, and a good spray adhesive makes the job so much easier. I love the cozy feeling the hull liner gives.
2. There is power in this trailer, but we opted for a number of LED battery lights as well (powered ones will come later, under the cupboards). My Favourite ones are the magnetic long ones on the roof. Simple and out of the way, and you can grab them to use as a flashlight at night if needed.
3. I made all the curtains and reupholstered the cushions. Someone on this forum said they used pine would and staples and I found this easy to do, although I did sew the corners for a clean tailored look. I used microbial fabric on the bottom and automotive upholstery on the tops.
4. We took out the little stove - primarily because it terrified me. Who knows how safe it was? My friend made a metal box I storage that got screwed in through the bottom and sits more or less on too of the icebox. It's a great additional storage compartment. An ikea cutting board with a fitted piece screwed on the bottom fit like a glove with no trimming.
5. My friend also designed an made the metal backsplash. After checking out options, I was worried about cost, but he was gracious enough to design and make this. We attached it to a 3/4 inch plywood and installed it, then attached these great ikea bars and storage units. They can be pulled off and stored quickly for travel and then set up again easily upon arrival.
6. I just need to point out the little quilted patchwork that my mom did. She loves this little trailer as well because it was her dad's and this little thing is a quirky bonus treasure, complete with my dog lounging in front with a cocktail.
So that's it! It's my little home away from home and I am so pleased. Looking forward to joining a meet up soon and learning more from all of you! Thanks again!!!
Attachment 73292Attachment 73293Attachment 73294Attachment 73295Attachment 73296Attachment 73297Attachment 73298
Evan Friesen 07-06-2014 04:33 AM
It's a flat-top Boler!
Great updates! I really like the upholstery and kitchen.
Happy camping :)
WildBirder 07-06-2014 04:16 PM
Very nice and simple renovations. What a difference :thumb:
The flat tops are rare. Do you know the VIN number? It should be three digits and located on the upper part of the trailer tung. Passenger side near the body. As far as can be found out there were only around two hundred of this mold made.
Thanks for the pics and enjoy
Evergreengirl 07-06-2014 09:25 PM
Classy renovations! I even like where you get to park it, under that cute arbor. It would make really cute guest accommodations.
Mary F 07-06-2014 09:44 PM
:woohoo Fabulous job, Suvi. I love it!
SimplyLesa 07-06-2014 10:58 PM
Soovi what a lovely and simple remodel. I hope you don't mind if I 'borrow' a few ideas from you. :)
Sent from my SCH-S968C using Fiberglass RV mobile app
Nelmes 07-08-2014 09:45 AM
Nice!!
CampyTime 07-08-2014 09:56 AM
This is an absolutely precious little trailer. Lots of love of family went into that. You did very nice work; functional and attractive. Nothing is perfect for long so don't worry about that. You love it and you should be proud and i am proud for you!
sooveroo 07-08-2014 02:44 PM
Thank you so much! Very kind of you. It's a treasure, for sure. Excited to use it more than work on it now ;-)
TBirdy 07-28-2014 11:29 PM
Love it. I'd love to hear how you mounted your plywood/ backsplash?
sooveroo 07-29-2014 08:48 AM
Thanks, TBirdy! Probably not the most sophisticated mounting job, but we just used adhesive on the 3/4 inch piece of plywood, which was wrapped with the metal sheet you see. From there, just screwed on the ikea components to the plywood. Probably not going to be way to remove if I ever want to take it back off but I think I am going to be happy with this for a long while :)
TBirdy 07-29-2014 09:56 AM
Right, but how are people mounting things (like your plywood backsplash board) to the actual inside walls of the Boler? I'd like to hang a wall clock for example but how to do so with no damage to the fiberglass? Thanks! I'd love to see yours in person someday, what city are you in?
sooveroo 07-29-2014 12:05 PM
Oh, sorry. Maybe wasn't clear. We attached it directly to the fibreglass with construction adhesive. Very easy to do, but like I said, no sure how hard it will be to remove.
For a clock, what about trying some of those 3M stickys. Not sure if you know what I mean, but they are the ones that usually come with the hooks. I am thinking that if you used just the two sided sticky piece that comes with the hook (I have bought just this part separately). Then you would be able to mount the clock but also pull it off easily if you decide you don't like it.
I'm in Vancouver. Happy to show off my little egg if you're in the area.
S
Glenn Baglo 07-29-2014 12:38 PM
If you are going to use the 3M Command adhesive pad without the hook part, keep in mind that you have to be able to grab the tab and pull it straight down. It will stretch and release. If you try to pull it away from the wall ( toward you ), it will likely damage the wall.
Above all, read the instructions and save them for removal.
