-   Electrical | Charging, Systems, Solar and Generators (http://www.fiberglassrv.com/forums/f95/)
-   -   Trillium '75 power cable (http://www.fiberglassrv.com/forums/f95/trillium-75-power-cable-66900.html)
Dietrich 10-19-2014 01:04 PM
1 Attachment(s)
The 3 pronged power cable that I plug from my trillium to the wall broke a prong. Is there a whole replacement part, or it it as simple as cutting it open and splicing in any generic replacement? Total newbie at all this.
Thanks in advance. Attachment 77847
Darnelle 10-19-2014 01:43 PM
Yep, you can buy just the plug and re-wire it to your cable. Just make sure to get the correct amp size.
David Tilston 10-23-2014 11:38 AM
Or, you could eliminate the cord and use an extension cord:
http://www.fiberglassrv.com/forums/f...ded-50948.html
My wife liked this, since it is one less place for bugs to get in.
Dietrich 10-28-2014 08:33 AM
Does anyone know the correct amp size for a 1975 Trillium 1300? Or know how I can find out?
David Tilston 10-28-2014 08:37 AM
If you have a converter, it is fused at 10A. If not there should be a breaker somewhere. Probably 15A. # 14 Cabtire will be fine.
Or just put a new end on the cable you have.
mszabo 10-28-2014 09:04 AM
That's a 30 amp plug and 10 ga. Cable you have.
David Tilston 10-28-2014 09:33 AM
Not to be argumentative, but that is not a 30A cable. That is clearly a 90 15A plug. The protrusion for the ground pin is visible. It could be a 20A, but that is doubtful.
mszabo 10-28-2014 10:10 AM
Is it a 10 ga cable?
David Tilston 10-28-2014 10:30 AM
Can't tell the gauge of the cable. Cabtire has really thick insulation. But, it would not make sense to use a 10 ga cable on 15A plug. Typically, 14ga for 15A, 12ga for 20A, 10ga for 30A.
A Trillium has no use for 30A. No AC.
mszabo 10-28-2014 10:34 AM
You think someone might of done some southern engineering.
And installed a 15 amp plug on a 30 amp cable?
Saved themselves $5 on a adaptor.
Don ravinerat 10-28-2014 11:06 AM
My 1975 Trillium has a 15 Amp fuse for the power cord. It is like a light socket screwed into the bench hatch on the door side. The power cord runs to it then the rest of the trailer.
