-   -   Removing Trillium body from frame (http://www.fiberglassrv.com/forums/f55/removing-trillium-body-from-frame-67335.html)
getaway1 11-24-2014 06:08 PM
Hello
Does anyone have any tips for removing the Fiberglass body from the frame on a 13' Trillium trailer. I want to know if the floor will support the rest of the body if I jack it up using plywood pieces to distribute the load on the floor jack. I must do some welding on the frame and access is limited with the body in place. Any help would be appreciated. Thanks Duane
David Tilston 11-24-2014 07:14 PM
There are several threads on this subject:
http://www.fiberglassrv.com/forums/f...ium-57834.html
http://www.fiberglassrv.com/forums/f...ame-29617.html
http://www.fiberglassrv.com/forums/f...ame-66137.html
The bottom is mostly flat. There are six bolts, four in the gaucho, two in the dinette that hold it on the frame.
