-   Towing, Hitching, Axles and Running Gear (http://www.fiberglassrv.com/forums/f72/)
-   -   ' 74 Boler tow prep (http://www.fiberglassrv.com/forums/f72/74-boler-tow-prep-68636.html)
Lisa in FL 03-24-2015 02:17 PM
' 74 Boler tow prep
Hi gang, I have a 13 ft Boler that has been sitting in a field up north for five years. I am planning a road trip to get her and tow her down south. Can anyone give me a checklist of what I should do before towing 1600 mls? And does anyone have a source for tires, bearings, other things I might need to take with me? I want to bring her south, fix er up and start full-time ing.
Sent from my C6530N using Fiberglass RV mobile app
FRED SMAILES 03-24-2015 03:45 PM
Unless you know the bearing and tire sizes no sense in taking anything with you,, do it there.
Obviously the lights, wiring need to be gone over, tape the windows and vent closed so you don't have to worry about them.
The ball size in my 74 boler was 1 7/8s and it was original.
Don't plan on making it home in the same time it takes you to get to it.
Welcome to the world of boler reno
Fred
Lisa in FL 03-24-2015 07:27 PM
Thanks Fred. Any input on checking the bearings, repacking etc. I want to get her back in one piece.
FRED SMAILES 03-24-2015 09:37 PM
If you've never done bearings before now with a 1600 mile trip in front of you is not the time to learn.
If the tires hold air and roll take it to a service center to ready it for the trail home.
If you can't get it road worthy to take to a service center a tow truck may be the correct choice.
I only know of Camping World centers in the USA but I'm sure that someone local where the boler is can steer you as well.
This is money well spent and service that is required sooner better than later.
Borrego Dave 03-25-2015 01:32 AM
Hi Lisa, Fred gave you good info. Sitting for five years....I wouldn't tow it any farther than a tire shop and then a garage for the bearings. If either of those go having working tail lights for the return trip would be mute. That's a long trip. Any chance that the seller could have those items done before you show up?
When I bought mine it had sat for two years in a driveway. I stopped a few times to check for hubs heat and that was only an 80 mile tow. Turned out OK but I did check and repack the bearings and brakes before I towed it again.
bullfrogeh 03-25-2015 09:45 AM
Hi Lisa;
If your Bioler is currently 1600 miles north, you can easily get the tires and bearings checked at the nearest 'Canadian Tire' store.
Lisa in FL 03-25-2015 01:26 PM
Hi friends, thanks for all your help. I talked to the guy who has been storing my Boler and he has agreed to repack the bearings and check the tires so she will be road ready. Yipee. Hope he doesn't charge me too much.
bobkatr1 03-25-2015 05:47 PM
' 74 Boler tow prep
Hi Lisa,
Some other things to consider:
Trailer light connection, if your connection doesn't match, you can pick up an adapter at most auto parts stores
Safety chains, have safety chain to car link that can be secured like a threaded link, this keeps the chains on, hooks fall off
Sitting that long, take or get extra light bulbs and a bit of emery cloth to clean contacts
Tires including spare and tire wrench and jack, even if the seller says they are O.K., check for cracked sidewalls and even adequate tire pressure, also check tread wear, if the inside or outside are worn the spindles or axle could be bent
Crawl under the trailer and check the frame, if it is straight with no breaks or bends great
Check the wheel wells, there should be room between the tire and wheel well, have the seller get in the trailer, the axle arms should move up, just watch the tire in relation to the trailer shell
Get a trailer ball lock, this keeps the hitch from coming loose and along with a receiver lock helps to deter theft
Hope this isn't too much. Be safe!
Bob
