-   -   7 way plug to 4 way plug back to 7 way plug (http://www.fiberglassrv.com/forums/f55/7-way-plug-to-4-way-plug-back-to-7-way-plug-70978.html)
immrbill 08-09-2015 06:15 PM
My Boler had a 7 way plug when I went to look at it and my Ranger p/u has a 4 way flat. When I picked up Boler the guy I bought it from had removed the 7 way and put on a 4 way so I could tow it home.
I am having a brake controller put in the pickup this next week which will include a 7 way and want to put 7 way back on the Boler.
I am thinking this will just be removing the 4 way from the Boler and putting on a new 7 way hookup
Casita Greg 08-09-2015 10:15 PM
1 Attachment(s)
You can get a new Tow Vehicle "pigtail" that has both the 7-Pin (which you will need with the brakes) and a branch off to the side of it for the 4-Pin Flat connector in combo.
You will definitely need to restore the 7-Pin stinger on the trailer as well.
WaltP 08-10-2015 09:37 AM
Actually it's too bad the PO rewired it. There are inexpensive plug in adapters that would have taken care of it much easier.
Walt
Casita Greg 08-10-2015 11:08 AM
Walt
True, I keep one in the glovebox. Just plugs into the 7-Pin and gives you a 4-Pin flat output. I also have one that converts the standard 7-Pin Bargman flat terminal to a 7-Pin round terminal plug too.
