-   Hobbies & Passions (http://www.fiberglassrv.com/forums/f83/)
-   -   Calling all ham radio people HF op in a Scamp? (http://www.fiberglassrv.com/forums/f83/calling-all-ham-radio-people-hf-op-in-a-scamp-71376.html)
gordon2 08-31-2015 09:13 AM
CQ CQ... This is a question for amateur radio operators with fiberglass trailers. I have seen a few of you on this forum, but to the rest of you, this might sound like Greek because of the “ham speak.”
I hope to operate portable 40-2 meters from a Scamp 16 and I am looking at antenna options. I have poked around on a few other web sites for suggestions but found most discussions were centered on larger motor homes. Of course, fiberglass trailers present some unique issues for HF operation.
I have not been on the air for about 15 years until this summer. At home, I just put up a half size G5RV dipole (which, despite its name, will not work with RVs ;) We all know the G5RV is a compromise antenna with serious shortcomings, but I have been quite happy with it, making a number of DX contacts. With the auto-tuner, it’s a simple matter to work all bands (40-10), and similar simplicity is what I am aiming for in the Scamp.
No mobile operation is contemplated, only stationary. I was thinking of using the 2-inch hitch (bike rack) receiver on the back of the camper to mount a mast. I do not want a setup that requires guy wires. Instead, I was thinking that a bracket on the spare tire carrier would be sufficient for a small HF antenna in normal weather. I will be using an Icom IC-7200 (100 watts max) and maybe the companion LDG Auto tuner.
I considered mounting a screwdriver antenna above the camper on the mast for some reduction in RF exposure but as I understand it, the screwdriver would then need ground radials or a counterpoise. I doubt the body and frame of the scamp would be effective for that, and I do not want to bother with running wires every time I deploy.
I thought maybe I would forget about the mast and use a TW antenna on the ground, but in small campsites it might not be a good fit, and it could become an attractive nuisance at a campground. It is also quite expensive.
Next on my radar was the Buddiepole. This one seems like it would be a good solution on a hitch receiver mounted mast up about eleven feet or more. But the Buddipole requires changing taps for each band, which I do quite often. If the antenna was at 11 feet, I would not be able to reach it to change the taps. Looks like it performs very well if you spend the time to tweak it however, one reviewer said, “Setting it up takes time to do it right” and another said, “is very difficult to tune.” I do like that it can cover all bands.. even 2 meters. Still I wonder if there is something easier to use so now I am leaning back in the direction of a screwdriver with radials, or maybe a BuddieStick. Seems its going to be a bit of a pain to set up anything that works reasonably well.
Maybe I should forgo 40 meters and just use a 20-meter dipole, inverted V style with the center on the top of the mast. Then again, it seems like there are often too many trees in the way to do that.
So I am open to suggestions. The Shelby (NC) hamfest is this weekend so I will be looking for an antenna there at a fair price.
My wants and needs for this portable antenna are:
• 20 / 15 /10 meters at the minimum (40 and 6 would be nice too)
• Less than 10 minutes to set up.
• Limits exposure to RF both to operator in the dinette and any curious passerbyers.
• Reasonably compact and lightweight
PS, I am also out of the loop (so to speak) when it comes to logging. Any suggestions for logging software that is both eQSL and LOTW compatible, and is a good general purpose logger but at least OK for contests. I am leaning toward DXLabs suite of software. However, I used Winlog32 in the past so the learning curve would be less with it.
minke 08-31-2015 10:44 AM
You may have already have read this: KBG.COM I regard him as authoritative.
I have't been on HF since the pleistocene era. Actually I'm not on the air at all except for APRS.
Alan,,, n4lbl
EscapeBoulder 08-31-2015 12:52 PM
Gordon2:
PM me your email address and I'll put you in touch with a friend of mine who's an RF engineer, built his own HF antenna for his home-brew RV, and might have some suggestions.
... Greg
WT0M
gordon2 08-31-2015 05:32 PM
  • Thanks Alan, that will keep me busy reading for a while. PS, I'm looking at the improvements in various digital modes also. I used to do packet but so much of ham digital stuff seems so efficient.
  • Greg, PM sent.
redbarron55 08-31-2015 06:31 PM
KE4MD here...
What year scamp? If it is an older one with the rhino hide insulation or a newer on with the reflextix they may behave differently for RF.
The bubble insulating aluminum flashed insulation may act as a shield and perhaps as a ground plane at some frequencies.
Perhaps a regular mobile antenna set or almost any piece of wire with an antenna tuner.
A nice automatic antenna tuner might be nice. As I have also been off the air for a very long time, I don't know what the tuner is capable of.
My last rig was a Collins S line. So it has been a while.
gordon2 08-31-2015 07:22 PM
Originally Posted by redbarron55 (Post 545483)
What year scamp? If it is an older one with the rhino hide insulation or a newer on with the reflextix they may behave differently for RF....
A nice automatic antenna tuner might be nice...
JD, it will be a new one with the foil sided insulation that is glued onto the roof and walls of the trailer. The effect of this insulation is one of the major factors I had in mind when I made my post. I suspect it will have largely unpredictable effects on radiation from the antenna, and I hope it will also provide some RF shielding for the operator in the camper, although much of the trailer’s shell is taken up by windows.
I do have the LDG Auto tuner already so I would be fine with using it in portable operation from the camper also. Various wire antennas (including a dipole) might work well if I don’t require 40 meters. Since I like to chase DX more than rag chew, I would be OK with that limitation.
In fact 15 and 10 are pretty much dead now.. and will be for some time. I have been on 20 almost exclusively, along with a little 40 meters So a mono-band antenna on the Scamp is not a bad idea.
Byron Kinnaman 08-31-2015 08:41 PM
I have a small 2 meter -440 antenna mounted on my truck. I find it somewhat useful while traveling.
For HF I use a mono EndFEDZ by Par Electronics, now LNR. I'm made a number of contacts with it.
I purchased two telescoping fiberglass poles a 19' from a kit shop and a 32' from another ham. I carry about 4 short steel fence posts, the kind you drive into the ground. Drive one into the ground and bungie one of fiberglass poles to it. If you're going to operate from inside the trailer put another close to power port of the trailer and her I would use the shorter fiberglass pole. String the antenna between the two in slopper configeration. A short pieced of coax to the radio and you're in business. No tuner needed.
I would suggest a secondary battery since hf at 100 watts draws close to 20 amps on the peak voices. I use a 50 amp hour battery and a 65 Watt solar panel to the keep the battery charged.
Most of the places I go 2 metes is useless. I do have the repeater book installed on my GPS so I can easily find the closest repeater. Since my wife is a ham also I can just let here do the radio settings while driving.
Equipment Yeasu 8800 with on receiver set to 145.62 and the other to some repeater.
Yeasu 857D. Operating at 100 Watts on either 40 meters or 20 meters.
The EndFedz antennas are tuned to the their specific band.
I find that a Buddie Pole works great but is alot of fuss tuning. It also take up more space and is heavier than EndFEDZ and associated poles.
That's what works for me.
Byron
AK7EE
73
Elizabeth EWA 08-31-2015 09:30 PM
Hamstick Dipole
One thing you might want to consider is a hamstick dipole. I used to have a setup that I used when I had a pickup truck camper many years ago.
Another is something like this:
versa-tenna.com - Our Story
or this (some assembly required):
http://www.earchi.org/92011endfedfiles/Endfed6_40.pdf
Both of these are like the EndFedZ except that they are non-resonant designed for use with a tuner.
I'll be very interested in what you come up with since I'll want to do something similar. Of course I still have to get a trailer and get it set up for camping but having a radio is high on the list.
frankcfx 09-01-2015 12:53 AM
Ham in a Scamp
I have a side dinette 16' Scamp. I have two batteries on the tongue, one feeding a 12 position power pole panel mounted under the front table. The battery can be separated from the trailer battery by a switch. Radio dc runs on a #12 pair under the trailer. A hole drilled through the floor under the seat provides power wire in and two RG 8 mini flex out with connectors on the end. I use a 40 Meter hamstick mounted on the belly band with a beam clamp. I also use a dual band vhf antenna mounted the same way.
If I can help let me know.
Frank Fox
AF0XX
AAR9FV
Borrego Dave 09-01-2015 02:27 AM
Gordon, had to chuckle when you said it was Greek to most of us. I was stationed in Greece and did learn a lot of the language but you are right...what you're talking about IS Greek to me :). I never got past the CB thing in the 70's. Calle nichta (?) good night.
jaevans 09-01-2015 09:10 AM
N0HJ here - not a FG trailer owner yet, but someday soon...
I would put up a mast and create an inverted V fed with ladder line to a coax balun before running coax into the trailer. Then I can use either an auto or manual tuner inside. My KX3 has a nice tuner for such use. Since I run QRP, I could have the inverted V ends almost to the ground.
GMike A 09-01-2015 11:38 AM
I will be interested to see what everyone says. I run digital JT9 at home and on the road I am too tired to do any Dxing as it seems I never stay in one spot more than a day. Perhaps some off-road in the future next year and stay put. Good luck
Casita-Freak 09-01-2015 04:35 PM
Antanna
I have been doing lots of portable operating from my Casita with a variety of antennas. I recently built what I call my Field Day Special wich is 85' of wire strung up like an inverted V end feed with a bifilar UnUn (home brew). I place a 50 ft counterpoise on the ground below the antenna. I use a 40 ft fiberglass push up pole for support. It tunes 80 through 10 meters with my AT-200 and Z11 tuners and has given me some great DX as well as good reports on 80 and 40. I worked over 300 stations with this antenna at Field Day this year.
I power the radio with a 100 amp AGM battery with a 150 watt solar panel charger which allows me to run 100 watts if I need to.
My QRZ page has pictures and I can send you more pictures if you like.
John WD5IKX
Casita-Freak
Byron Kinnaman 09-01-2015 05:16 PM
John WD5IKX
Casita-Freak
You don't need quite that much power to run a full 100 Watts. I powered my radio 2 years in a row for field day, day and night, using a 50 amp hour battery and a 65 Watt solar panel. My poor old 50 amp hour batter is about gone so I'll replace with another 50 amp hour battery. And still run 100 Watts.
