-   -   Looking for a lock cylinder or key for my Cadet (http://www.fiberglassrv.com/forums/f55/looking-for-a-lock-cylinder-or-key-for-my-cadet-72936.html)
sandoz 01-08-2016 09:18 AM
I just purchased a Cadet but I can't find the keys. I've drilled out the propane tank cover lock and removed the door lock. I should have never drilled out the one lock because they are the same lock cylinder and there's a good chance they shared the same key.
I've been to a few locksmiths around town but they can't find the blanks to make the key from. I was thinking of replacing the complete cylinder but can't find one that looks like the original one.
Does anyone know where I can get a new lock cylinder from?
It's a 1986 Cadet
Thank you
Jack L 01-08-2016 09:46 AM
I would suggest you post a photo or two of the lock and key you need. A 30 year old trailer may have had a lock assembly changed. A photo migh help identifying the lock manufacturer.
Jack L 01-08-2016 09:52 AM
I just noticed you have 2 threads started on the same subject. One would be better.
sandoz 01-08-2016 10:08 AM
Pics
Sorry, I'll post a pic tonight.
floyd 01-08-2016 10:29 AM
That trailer is common in Europe, manufactured in Poland under a different name. It was called a Predom, but I think it had two names.
Here is a link made by the former owner of a trailer which I bought several years ago there may be some info of value or at least of interest...^_^
Our 85 Cadet
Uplander 01-08-2016 11:30 AM
Check with a qualified locksmith with a fully stocked shop. Just about every lock set in every travel trailer is generic and only a few types are used in the industry. Once you locate the right locksmith just tow the trailer to his shop and the job will be done in a matter of minutes.
My local locksmith told me he had key blanks and lock sets for just about every RV .
Since your travel trailer is foreign made he might just change out your current lock set for something more easily matched in the future.
Good luck.
sandoz 01-08-2016 05:53 PM
Pic of the lock cylinder
1 Attachment(s)
1of 3
sandoz 01-08-2016 05:55 PM
Another pic
1 Attachment(s)
2of 3
sandoz 01-08-2016 05:56 PM
Can't post more than one at a time
1 Attachment(s)
Pic 3
camperpete 01-14-2016 01:21 PM
Hi,I can tell you (from the UK) that the cadet (freedom microlite or earlier models were called N126 over here) were originally made for the fiat 126 car- my 1986 n126 has fiat keys with fiat stamped on them, try looking on ebay uk! !
camperpete 01-14-2016 01:28 PM
Iv just looked on ebay uk and you can buy 2 barrels with 3 keys ,the end of the barrels are different but the keys and the guts/spring loaded brass lifters will swap over (keep them in order 123456) or just blank keys!
MRClaus 01-14-2016 02:04 PM
try a truck shop looks like a tool box key set
PerH 04-10-2016 09:05 AM
It's good to know that Fiat locks might fit. Polskie Fiat was a very common car in Poland during the communist years, so it make sense that the manufacturer of the caravan used a lock that available in big quantities in Poland at that time.
There's also an e-shop in Germany that sells parts to the caravan:
www.niewiadow-ersatzteile.de/start/aufbau-1/schlösser-scharniere
