-   -   Wooden horizontal supports: how to replace? (http://www.fiberglassrv.com/forums/f55/wooden-horizontal-supports-how-to-replace-73073.html)
Uncle Cereal 01-19-2016 10:47 AM
Any hints on replacing the wooden support at each end of the Boler? They are used to support the table at one end and the top bunk at the other...
RogerDat 01-19-2016 12:00 PM
Are they wood fiberglassed to the wall? That is called tabbing, and the Google site search under the search link (upper right navigation bar) might bring up some posts on the replacement process if you search for that. Otherwise I'm sure someone that has done it will chime in soon.
Rick Mooyman 01-19-2016 01:14 PM
They are both fiberglassed into place. if you need to make new ones the old ones can be used as patterns if not some cardboard and lots of trimming to get the shape and then epoxy or PL Builders glue to the wall and fiberglass to permanently mount it.
Uncle Cereal 01-19-2016 01:27 PM
Roger and Rick, thank you both: very useful! The "tabbing" search gives mostly "cabinet tabbing" results, but I'll look some more and I think it's very "doable"...
Uncle Cereal 02-05-2016 11:50 PM
Here are the most interesting related threads I found.
http://www.fiberglassrv.com/forums/f...w-53917-2.html
http://www.fiberglassrv.com/forums/f...ing-41957.html
http://www.fiberglassrv.com/forums/f...ing-44116.html
Roger, you didn't want to brag about it, but you did quite a job on yours!
It doesn't seem hard but quite a job regardless! I might wait a few months before I tackle that job. I'm not sure how to move ensolite out of the way for tabbing...
P.S.: This video seems useful.
Uncle Cereal 02-09-2016 08:56 PM
Does anyone have a clue on how to remove the ensolite in order to do the tabbing of the new board?
redbarron55 02-09-2016 09:28 PM
I used a wood chisel to cut out where I bonded in the bulkheads and cabinets.
A wire brush and drill to rough up the surface.
