-   -   Attaching the table to the wall? (http://www.fiberglassrv.com/forums/f55/attaching-the-table-to-the-wall-73100.html)
britneydawn 01-21-2016 01:13 PM
1 Attachment(s)
Hi! I bought a 1971 boler project and have ordered a table mounting kit from Scamp. We figured out how it all works however there is a piece of wood under the window in the way when the table swings up. We want to replace it with something sturdy and wider to attach the table hardware. I have seen this done in pictures but does anyone know how to get that piece out without making a mess of the wall around it? The previous owner who started the project has already painted the interior and we aren't sure what its been painted with. It feels flexable and kind of rubbery, any ideas on what kind of paint this could be?
CliveAlive 01-29-2016 01:06 PM
2 Attachment(s)
Hi Britney;
I see no-one has answered you yet so I will tell you what I did on my Boler in case it helps.
I did a dinette conversion on mine so I had a similar situation to solve except mine was at the front.
I beefed up the "shelf" by sistering up a piece 1/4" ply. I varnished that to match my table but it was also to strengthen the existing wood there.
That wood was glassed in on mine so I didn't want to mess with removing it.
If you are talking about the rubbery insulation in the Boler, it is more than likely the original Ensolite. Popular opinion tends to favor keeping it if it is at all salvageable. Easy to paint over. Your paint could be acrylic.
Hope this helps.
britneydawn 01-29-2016 01:57 PM
1 Attachment(s)
Thanks! That does help me a bit. I've been thinking my answer is probably going to be cleaning up what is in there and maybe just adding pieces underneath where I need them. I'll attach a picture of the table hardware from a scamp, the top brackets are just too wide for whats there. And the paint I gave it trying to match, repainted the interior this week. I'd rather bright white and clean instead of off-white anyway. We repaired a few things with calking before the paint and I'm impressed with how nice it all came out in the end.
CliveAlive 01-29-2016 02:10 PM
OK. I see you bought that other style of table attachment.
My rear table was attached with a bracket the same style as I used on my front table as pictured.
From your photo above I thought we were talking about the same thing.
Still, like you said, you could just sister up some timber underneath what you have to make it wide enough and sturdy enough to mount your hinge/brackets.
Good luck.
Uncle Cereal 01-30-2016 11:37 AM
Clive,
Your answer gives me some ideas to avoid changing the wooden piece altogether. I'll be visiting my trailer this afternoon and see if your solution is enough for now. That'd be really nice... So thanks for posting!
CliveAlive 01-30-2016 05:55 PM
Originally Posted by Uncle Cereal (Post 569134)
Clive,
No problem; glad to help.
Let us know how it works out?
britneydawn 02-12-2016 02:00 PM
1 Attachment(s)
Well, its done! The ends of the plywood on the wall were gross and swollen from maybe moisture or something? So we took them off as nice as we could(I wish it was a little cleaner of a cut but I guess its 45 year old plywood) and added an extra piece of bamboo from the table on top of the plywood. Now that its painted to match the wall its not too bad. Without this mounting hardware set-up there is no way I could move the heavy bamboo table up and down by myself. Very happy with it. Thanks a million for those pictures!
CliveAlive 02-14-2016 03:01 PM
That table looks really nice.
Glad it worked out for you.
