-   Electrical | Charging, Systems, Solar and Generators (http://www.fiberglassrv.com/forums/f95/)
-   -   Fill level on a deep cycle (http://www.fiberglassrv.com/forums/f95/fill-level-on-a-deep-cycle-81506.html)
RogerDat 08-19-2017 01:11 AM
Been a long time since I bought or used a deep cycle wet battery. But in the past I recall they were filled to the bottom of the "tube" going down from each cell cap.
Just bought a group 27 and all the cells appear even but the are all about 3/16 to maybe a 1/4 inch below those tubes.
I was about to go grab some distilled water and then got to thinking maybe I'm not remembering correctly on how full the cells should be.
Anyone know how far below the caps a conventional wet battery should be filled?
RogerDat 08-19-2017 05:54 AM
Google is mighty useful. It was late and I was trying to get a top charge before use so I sort of panicked in the wee hours.
Found this:
Batteries should be watered AFTER charging UNLESS plates are exposed before charging. If exposed, plates should be covered by approximately 1/8″ of water. Check water level after charging. The water level should be kept 1/4″ below the bottom of the fill tube in the cell cover
So mine are properly filled, properly trickle charged and are going to get properly (we hope) hooked up in my new tongue mounted battery box. :wub
gordon2 08-19-2017 07:33 AM
I am not even going to google this.. and just give an opinion. Add enough water to fully cover the plates and then a little more so that the plates do not become exposed due to evaporation before the next time you check the water level, but not so much that the water (acid) bubbles up and out of the battery during a heavy charge cycle or when the battery experiences normal amounts of tilting and movement on the road.
The important thing is that the plates are not exposed.
Mike_L 08-19-2017 10:15 AM
All good advise so far. Make sure the plates are covered with electrolyte before you charge. The battery may heat up during charging, the electrolyte expand and the level rise. After charging you may need to top up with DISTILLED, not tap water to the bottom of the fill tubes. Water is consumed during the charging cycle and needs to be replaced as necessary. Excessive water consumption is a sign of battery problems.
The Minimalist 08-19-2017 10:31 AM
As above, I fill to the bottom of the fill tubes. The key is not to cover the slots in the sides of the tubes, they are there specifically to allow the gas produced during charging to escape. If you cover them, the gas pressure will push the electrolyte out of the caps.
panhead_mike 08-19-2017 10:34 AM
..or a sign of over-charging the battery. Check your charging source.
wbullivant 08-19-2017 12:02 PM
I fill my GCB's to the bottom of the fill tube when they are fully charged. I generally use a flashlight and carefully add water till I see a curved water surface around the periphery of he opening. What's happening is that when the electrolyte touches the fill tube capillary action makes it curve upward. A little hard to explain but once you try it you will easily be able to recognize the change in appearance of the surface when it is at the correct level.
