-   Care and Feeding of Molded Fiberglass Trailers (http://www.fiberglassrv.com/forums/f54/)
-   -   1988 Perris Pacer renovation (http://www.fiberglassrv.com/forums/f54/1988-perris-pacer-renovation-85008.html)
ValleyReb 05-08-2018 08:36 AM
4 Attachment(s)
I thought I'd share the journey we are on right now to get this little beaut back in action.
I'll start with how we found this poor girl, on a farm in Virginia. It had moss and lichen growing on it! Lichen!! :omy
ValleyReb 05-08-2018 08:40 AM
Brought it home to clean
4 Attachment(s)
Towed this with my Honda Element. Time to get to work!
ValleyReb 05-08-2018 08:42 AM
Waxing time...
4 Attachment(s)
Gave it a bath and ran a buffer with rubbing compound and then waxed it.
fofobraselio 05-08-2018 08:42 AM
Right on!
Look forward to following your progress :)
ValleyReb 05-08-2018 08:44 AM
renovation of the interior
4 Attachment(s)
Tore out the old carpet and flooring, sanded the fiberglass walls and took the cupboard doors off to have them refinished.
ValleyReb 05-08-2018 08:47 AM
New LED running and brake lights
3 Attachment(s)
Had a lot of trouble connecting the lights to the Honda. the camper came with a 7 pole connector and the Element runs a 4 pole. So I had to use my multimeter to trace the lines and get the correct wires to convert the 7 to a 4 to match the tow vehicle. Once I had that done, I Checked all the lighting and replaced all the incandescent bulbs and fixtures with more efficient LED lights. I will also be replacing the interior incandescent fixtures with LEDs too. This will save on my battery power and the LEDs will have less draw on the elements electrical system when I tow it.
ValleyReb 05-08-2018 09:02 AM
got the furnace working
1 Attachment(s)
Had to break out the schematics and go through the furnace, I really wanted to get this working. We'd like to be able to camp year round so have a working furnace was paramount. At the end of it all it was just a blown 4 amp fuse. Now it works fine.
blueruby 05-08-2018 09:34 AM
Looking forward to your reno. Do you not have kitchen support bracket?
Bruce
ValleyReb 05-08-2018 09:41 AM
I am new to this so what is a kitchen support bracket?
WaltP 05-08-2018 10:55 AM
Nice to see another reno on a vintage. Quite the transformation on the outside. Can't wait to see the restored interior. Keep up the good work.
Walt
alan H 05-08-2018 02:45 PM
I had a pacer
Unlike the scamp trailer my trailer didnít have the supporting bracket either
( FYI some but not all have a brace of some type that goes from end of counter to roof to support the roof especially if you have a roof a/c
ValleyReb 05-09-2018 07:11 AM
New door moulding, propane tank, battery & box
3 Attachment(s)
For the door moulding I used is Metro Moulded IS-MW00100 Door Seal, I ordered one box off of Amazon $35, fits perfect, I think I had 3 inches left over to trim off. Bought a new Deep Cycle Marine battery with 105 amp hours at Walmart for $75. I will be buying a solar trickle charger to keep the battery charged. and a 12 volt battery switch to put inside the camper to turn the battery on and off to save power. Box for the battery was also a Walmart buy for $7.50 The regulator for the propane had to be replaced so I bought one that had 3 feet of hose with it and replaced the entire connecting line, teflon taped the connectors and bolted the tank down. 12 volt system is running perfectly now.
ValleyReb 05-11-2018 08:51 AM
Installed interior LED's last night
2 Attachment(s)
1. Kohree 12V Led RV Ceiling Dome Light RV Interior Lighting for Trailer Camper with Switch, White(Pack of 2) $27.00
2. 12V Led RV Ceiling Dome Light RV Interior Lighting for Trailer Camper with Switch, Single Dome 280LM $10
3. LED RV Exterior Porch Utility Light with Switch - 12v 280 Lumen Lighting Fixture. $11
ValleyReb 05-11-2018 09:20 AM
Originally Posted by alan H (Post 696617)
I had a pacer
:thumb
blueruby 05-11-2018 07:43 PM
LED Lights
:okra:cheers:ola:thumb
COOL
rbryan 05-11-2018 08:00 PM
Nice job cleaning up so far. Would like to see photos of the interior when completed.
CalCop 05-13-2018 11:26 PM
Great job with the clean up! I'm very impressed
Now onto the interior :)
Evergreengirl 05-13-2018 11:52 PM
Youíve made great progress and your little camper is already looking 100% better! Keep the pics coming.
ValleyReb 05-14-2018 06:56 AM
thank you!
thank you!!
