-   -   Upgrading scamp kitchen window (http://www.fiberglassrv.com/forums/f55/upgrading-scamp-kitchen-window-89469.html)
WDavidG 06-21-2019 07:32 AM
We have a 2014 scamp 13 (no bath) that has an 8x18 crank out window with frosted glass that provides some ventilation but no view for the cook. It appears from photos posted on this forum that the newer 13s are built with a larger kitchen window - probably the 11 x 18 listed on the scamp parts website. Can one of you with the new trailer confirm this?
Were considering upgrading to the larger window. Any thoughts on whether this is or isnt a reasonable idea? Im moderately handy with tools and have made some internal mods involving cutting the fiberglass but havent yet been brave enough to penetrate the hull. It appears that with a template to guide cutting a larger opening and fitting a new window while not trivial should be relatively straight forward, but I dont know enough of the install details to know what to be concerned about.
Well be within a day of Backus on a fall trip so an alternative if this is over my skill level would be to see if the Scamp factory would do the install.
Any advice and guidance will be appreciated.
Jon in AZ 06-21-2019 09:47 AM
As long as its not smaller in any dimension, installation is straightforward. The increased height should allow you to compensate for any difference in the corner radius.
On the other hand, if you wait and have Scamp do it, what you save on shipping now might well pay for the installation labor. Windows generally have to be crated and shipped by common carrier.
That window is a available in both clear and frosted. Normally Scamp puts a frosted window behind the stove to avoid having curtains near a flame. If you want a view, youll want the clear one. Then youll have to figure out privacy when you need it.
thrifty bill 06-21-2019 11:17 AM
No brainer here, have Scamp do it. The times I have seen people post what Scamp has charged for installations, I am always pleasantly surprised by their reasonable costs. Imagine having the Ford factory do an installation on your truck! Cheap? Not a chance.
Avoid the shipping hassles on a window, crating, damage or whatever. And a worker at Scamp that probably has installed thousands of windows can do the job so much faster, with the right tools and supplies in hand.
Glenn Baglo 06-21-2019 12:02 PM
Wouldn't the window have been provided by a window manufacturer, like Hehr? And wouldn't a glass shop near the OP be able to order the window and install it. Cheaper than driving to Scamp.
thrifty bill 06-21-2019 12:09 PM
Except poster stated he was going to be near Backus this fall. I would much prefer Scamp do it than myself, or a local window person either.
Jon in AZ 06-21-2019 03:37 PM
I dont know if it would be. By most accounts, ordering a custom window directly from Hehr is more expensive than a stock size from Scamp, and youd still have to pay shipping and installation labor.
Donna D. 06-21-2019 03:44 PM
The issue isn't just cutting the hull, it's trimming the Reflectix and Rat Fur... neatly.
WDavidG 06-21-2019 05:30 PM
Agreed Donna. This is the sort of potentially tricky detail that worries me. First time is when you make most of your mistakes and I only plan on one time for this process so I'll be starting and ending near the bottom of my learning curve. The scamp folks presumably have a lot more experience though I'm not certain how often they modify an already built unit.
LyleB 06-22-2019 06:02 AM
Just call Scamp and ask if they will do it and cost.
I have had things installed by the Scamp factory and they only charged the normal price, if you had bought the item as an option on a new trailer. Fantastic Fan, new door seal. Plus, they checked and cleaned out the hubs on my newly installed axle (not by them) when it started throwing grease. They did not charge for this and assured me there was no problem other than slightly over filled bearings. That turned out to be correct.
They took my trailer directly into the shop when I arrived for my 8 AM appointment, and I was back on the road on my vacation by noon, just as they promised.
The kicker, was that when I was making the payment for the service, they brought out a new door curtain for me. I had mentioned that I had tried washing it, and it had shredded. They chuckled when I told them and said, yeah it wasn't a good idea to wash them, even by hand. No charge for the curtain for my 1999 13 ft. I hadn't even bought the trailer from them, I was the third owner..
I cannot say anything negative about any of my experiences dealing with Scamp or their employees. While I was there, I noted an Airstream Trailer parked out back. The service guy said they were gutting and re-fitting the entire interior of the Airstream. He told me they will work on any brand of trailer, but Scamps take first priority if they get backed up.
My recommendation? Have Scamp do the install.
Jon in AZ 06-22-2019 06:06 AM
I think youd want to loosen several inches of the lining around the window opening after you remove the old window. Wedge something in between- pieces of molding, perhaps- to separate the lining and the shell while you cut the fiberglass from the outside.
Control the depth of the cut to avoid snagging the lining. Use tape along the cutting line to minimize damage to the exterior gelcoat. Eye and respiratory protection are essential when cutting fiberglass.
Then trim the lining back to the new opening with scissors and re-glue. The window flange and trim ring cover the cut edges.
Doable, but I still think Scamp is the best option. Wish I lived closer!
David B. 06-22-2019 12:36 PM
I’ve installed two of the small frosted glass Scamp windows in our Lil Snoozy in the bed area. I had previously glued reflectix and marine headliner in that area, and when I cut the openings, I used a multi-tool (vibrates like a saw for cutting off a cast) for the straight cuts, and a saber saw for the corners. The reflectix and marine headliner (rat fur) simply cut along with the fiberglass, so no trimming was needed.
Dave & Paula
P.S.
I think that I would take the easy way out and simply remove the window and take it to have a clear glass pane installed, and simply re-install.
WDavidG 06-22-2019 01:27 PM
I have had things installed by the Scamp factory and .....My recommendation? Have Scamp do the install.
Thanks for sharing your positive experience Lyle. I had no reason to doubt their good work but your report makes me even more confident that this is my best approach. Is there a particular person at Scamp that you made arrangements with?
WDavidG 06-26-2019 03:54 PM
To bring this thread to a close I'll report that thanks to your advice and suggestions I have scheduled the window replacement by the Scamp factory later this season when our travels will bring us close-ish to Backus. As several of you mentioned, their cost is amazingly reasonable - little more than my cost for the window and shipping would have been.
Thanks to all of you who provided helpful comments.
LyleB 06-26-2019 04:25 PM
I think I first talked to Micha (sp?) But I'm sure others will be just as helpful.
WDavidG 10-06-2019 12:35 PM
I thought I'd post a follow-up report on the end result of my window quest. As several of you suggested, I did arrange for Scamp to do the work, scheduled for a day we were near Backus on a fall trip. I am very pleased with the result. Their installer did an excellent job and we were back on the road within two hours. The total install labor cost was only $100 and of course there was no shipping cost.
While talking with the installer I discovered another benefit in having them do it. Apparently they are having significant problems with manufacturing defects causing leaking in the windows they have been receiving in recent months. They need to water test each one after installation and experience a non-trivial percentage of replacements required. Had I had one shipped to install myself I might have been stuck with a leaker and a real mess in more ways than one. As it was they were able to test it before we departed.
Thanks again for all the suggestions.
cwallace fl 10-09-2019 03:17 PM
I enjoyed reading your posts since I have considered doing the same to my kitchen window and was wondering if you had changed the size of the window to a larger one as you had mentioned in your earlier post or used the same size.
WDavidG 10-09-2019 03:40 PM
Catherine,
Yes, we had the larger 11"x18" installed. I believe this is what they are now installing as the default kitchen window in the 13's. You have a choice of clear or frosted glass and we opted for the clear to get the view. Since curtains aren't safe over the stove the clear glass requires a different means of providing privacy and darkening. For the trip home I simply cut a piece of corrugated cardboard with a notch that slipped over the crank shaft and held it in place for nighttime use. I haven't yet fabricated a more permanent fix, but there are several promising approaches to create a simple and functional solution. We love having larger window and additional view from this window - makes a big difference in the feel of the front area of the scamp.
