-   -   subfloors for compact jr (http://www.fiberglassrv.com/forums/f55/subfloors-for-compact-jr-89510.html)
N5td 06-26-2019 04:06 PM
best material for subfloors on a compact jr? OSB? CDX? Anything else?
Brian Dale 06-27-2019 11:42 AM
I just replaced the floor in my 72 Compact Jr and I used that osb sturd-I floor! Couldn't be happier with the results. As long as the potential leaks above the floor(windows/vent) are sealed really well, then any one of the subflooring materials you listed would work
N5td 06-27-2019 11:43 AM
Thanks for the response!
Did you use three pieces of OSB to make the floor or just one?
Brian Dale 06-27-2019 11:56 AM
Just a single 4x8 sheet front to back notched about 4 inches in where the wheel wells start. For the sides over the fiberglass "lip" I placed in 1x10 and used mending plates to tie them into the osb. I figured that area will be covered with bed/seating anyway
