-   -   Cracked AC Shroud (http://www.fiberglassrv.com/forums/f55/cracked-ac-shroud-89592.html)
Lisa M. 07-03-2019 05:47 PM
Cracked AC Shroud
There were two small cracks at the screws and my husband took the AC shroud down to repair with some special glue. The shroud was so brittle it literally went to pieces on the table. Casita is closed and I can't get help from them. I leave on a camping trip Tuesday, so I need to deal with this immediately (and 4th of July weekend doesn't help!). I'm looking on Amazon for a replacement shroud and can't figure out which one to order. On the AC inside the trailer it says BriskAir by Dometic and Duo-Therm. It is a boxy cover with a slight slope to the front. There are three screws on each side, plus an additional one on each side at the back. Can someone look at Amazon and give me some advice on which to order. Some models have too many screw holes. In the pictures there seems to be a gray band at the bottom which mine doesn't have. The indentions on top seem to differ also. Mine has vent slots that go straight up and down almost the whole height and about 2/3 the length (until the slight slope). I'm sorry I can't post a picture. Please, can someone help me! Posted on Casita Forum also. THANK YOU!
Radar1 07-03-2019 05:56 PM
1 Attachment(s)
Does it look anything like this shroud at Camping World?
Lisa M. 07-03-2019 06:41 PM
Camping World! Great idea! The one I see on their website is slightly different—it doesn’t have the gray band at the bottom. Mine also has larger vertical vents and fewer screw holes. Also, the decorative indents on top are different. Let me call them. They aren’t too far away to drive to.
floyd 07-03-2019 06:53 PM
When our trailer was new, we replaced the washers on top with
1-1/2" X 1/8" strips of aluminum cut full length of the shroud top.
Simply drill two holes in each strip corresponding with the hold down bolts.
The strip acts as a large and effective washer and will prevent the shroud from cracking.
Radar1 07-03-2019 07:14 PM
1 Attachment(s)
I borrowed Floyd's idea from him, although I just used two aluminum strips on the front section.
Lisa M. 07-03-2019 07:46 PM
I’m talking about trying to find a correct new shroud to fit over the top of the AC unit. The screws run horizontally into the plastic shroud to hold it on. But I’m glad that worked for you.
Finally found the model number, and that along with some exact measurements find me the correct size. Thanks!
Joe Romas 07-04-2019 02:13 PM
Not hard to find at all. I replaced the cover on my 1999 Brisk Air. The original is open across the back and the new one has vertical spaces like the side. They seem to cut down the cooling a little and can easily be cut off but I like how it looks. You may want to contact the vendor to verify it fits your model.
https://www.ebay.com/itm/ICON-Brisk-...55c3%7Ciid%3A1
Jann Todd 07-04-2019 05:30 PM
Most RV supply stores will sell them. I've had to replace a couple and that's where I got them. Make sure to get the right one or it won't fit and work right. If you don't have the manual then take the trailer to the store to get it.
Captleemo 07-04-2019 10:25 PM
Might not be a bad idea to take those shrouds off occasionally and spray paint them to protect the plastic from the UV rays of the sun which is what causes them to get brittle in the first place. Modern spray paints usually say on the can if they will work on plastic.
floyd 07-04-2019 10:47 PM
"Go2" glue is excellent for that type of material.
I have used it to glue vinyl (cut from "J" channel) to the inside shroud of an A/C unit about 4 years ago. It was glued and clamped overnight to close over a stress crack and provide reinforcement. Today it appears as new with no sign of the repair.
Again just an alternative to purchasing a new shroud, maybe only until a new one is procured.
Borrego Dave 07-05-2019 12:19 AM
Not to hijack the tread but about glue...on a class A I had, the rear plastic panel that had the tail lights in it cracked. I pulled it, cut some PVC pipe to re enforce the ribs and used PVC glue on it...big mistake as it melted the panel. Make sure any glue you may use for any plastic repair is OK for the material before your hands get in gear....or it can be expensive ;).
Lisa M. 07-05-2019 09:58 AM
Interesting idea. I wonder if anyone else has tried it. The shroud was literally disintegrating—just touching it caused cracks. No glue would make a difference, but thanks. I have ordered the shroud, but the soonest I could get it here is next Wednesday (darn 4th of July weekend!) and I leave with the trailer on Tuesday. I think Tom said something about wrapping it in plastic and duct tape to get me by and he will put the new one on when I return. Obviously won’t be using it while I’m gone, but doubt I would have needed it anyway. I’ve only used my AC maybe 2 or 3 times in 12 years. Usually we boondock.
tractors1 07-05-2019 12:02 PM
PVC glue is not truly "glue" in that it has several plastic solvent ingredients. That's why it dissolves and seals so well. Might try Gorilla Glue (comes in clear now) and do paint with a plastic paint (no primer needed for those.)
Captleemo 07-05-2019 01:46 PM
Something else that you can do is to occasionally put some Armorall or whatever your favorite protectant is on a paper towel or rag and apply it to the shroud. Ant thing to protect it from the UV rays.
