-   -   Classic Boler Bulge/ Door Issue + Mystery (http://www.fiberglassrv.com/forums/f55/classic-boler-bulge-door-issue-mystery-89633.html)
Squamoton 07-06-2019 05:59 PM
***Tried posting before, didn't save so excuse the brevity :)
Proud new owner of Wes, the Boler. But sadly he has some issues....which I think I've worked out through the amazing threads and comments found here! :)
Before I break anything, I wanted to share some photos and a quick history.
- The Boler sat for 3 years, with only the cupboard in place.
- The width of the door (top) is 25.25"
- The width of the door (bottom) is 26.5"
I am planning to do the following:
1) Jack up the roof (see pic)
2) Straighten the metal bar
Any thoughts and comments from the gurus here, would be most appreciated!
P
PS - wont let me upload photos....I'll try after I post this thread.
https://drive.google.com/file/d/1xJS...ew?usp=sharing
https://drive.google.com/file/d/1xHX...ew?usp=sharing
https://drive.google.com/file/d/1xJV...ew?usp=sharing
https://drive.google.com/file/d/1xJY...ew?usp=sharing
Squamoton 07-06-2019 06:03 PM
https://drive.google.com/open?id=1xF...m&usp=drive_fs
https://drive.google.com/file/d/1xHS...ew?usp=sharing
Menno 07-07-2019 08:21 AM
Also check the frame for cracks and the axle for sag if it has been sitting for a long period.
Dan Meyer 07-07-2019 02:20 PM
For some strange reason there are no thumbnail pictures - only blank placeholders. Also, I need to click the back button on my browser to come back to the thread... but enough computer strangeness.
Back to the camper. Can you provide a couple more pictures? I'd be interested in seeing the whole door opening and open door in one photo, a picture of the whole door, and a picture looking down each side of the camper.
--Dan Meyer :steer
Squamoton 07-07-2019 03:17 PM
Hi all......I've uploaded photos to Google drive here: https://drive.google.com/drive/folde...Tf?usp=sharing
*note: I don't really understand how you are supposed to upload photos? It asks for a URL for each photo - I have to double click the upload image icon to get a pop up window.
I used the public link from from the Google drive photos in the previous post, adding the [IMG] html prefix in the text....maybe reason black images.
Squamoton 07-07-2019 03:18 PM
Photos
I just replied...awaiting moderation.
Replying here too....Public link to of photos:
gordon2 07-07-2019 04:21 PM
You can link to photos off site as you have done, or using the "Insert Image" option, but attaching photos to the post is the preferred method. On a web browser, choose "Go Advanced" option for posting a message, then look for the paperclip icon on the top row above the message composition window. Also see Fiberglass RV - FAQ: Reading and Posting Messages
Glenn Baglo 07-07-2019 04:36 PM
The easy way to post photos.
These illustrated instructions are at the Escape Forum, but same process as here:
Posting Photos - Escape Trailer Owners Community
Borden 07-08-2019 09:52 AM
Had a door problem on our boler, was the wall had spread out at the bottom away for the inner floor; pulled wall back and the curve was fixed.
Door hinges had also sagged new pins and the holes holding hinge to trailer wall had worn allowing the top hinge to move to left so removed hinge and filled the holes then re-drill new holes in the proper places 1/8 inch over and up for top hinge.
Door had not sagged at the bottom as it looked, but the wall had moved out at floor adding to wall curve. also added brackets at curved steel wall brackets on each side of door and screws at the floor across in front of door into the original floor plywood to increase strength.
Roy in TO 07-08-2019 02:15 PM
I may comment more after I see your photos. There are many structural designs in the various bolers over the years.
IMO, the metal bar does not bend, so it does not need straightening.
Your body will bulge from the upper and lower points of attachment of the metal bar. i.e. it rotates outward from the lower and inward from the upper. When looking at the "door frame" from the outside, there is typically a crack in the top right corner.
Try making a template from your closet side of the door and you will get an idea. That is if you still have the closet in place. I have an extra closet if needed. You just need to figure out how to get it to the Wet Coast.
Stephen_Albers 07-13-2019 10:17 AM
Common Problem
Common with small trailers, your frame is not strong enough to support the shell - a problem for all operations including just sitting over time and a disaster for boondocking operations. Before considering shell repairs, you need to provide a stronger custom frame.
