I have had my 05 Escape [plan B] since last September. I like to get away from people, so I tend to camp at Forestry sites[ Remote, no services] in British Columbia. I'm 6 ft. tall and have to crouch or sit to shower,but it beats having to jump in a glacier fed, steam,creek, river, or lake in early spring or late fall, to get clean. "I"can live with the size of the shower,it was not a high priority when "I" was looking for a trailer. I looked at the whole package,and it suited "MY"needs.
Now you know why we are hardpressed to answer questions like "which is the best?". They are ALL great trailers, so it just depends on each person's needs. Truly, my personal favorite would actually be a mixture of ALL of them. They each have something I like about them. The trick is to find the one that best suits YOUR needs, just like Erik did.
One thing that I've noticed since this forum started is that the majaority of us love the one we have. Sure, we'd like a few changes here and there, but, secretly, we think we have the best one. And THAT is the reason I know they're ALL great trailers and very thankful that this forum exists so we can all have a place to hang out together.
Roger is right, of course, about the complexities of auto versus RV sales and service; however, the difference is perhaps not so clear-cut. It certainly is possible for an independent shop to do just about any service any vehicle (although a $200 factory manual is often required), even though it is certainly easier to do this with trailers.
Independent auto shops and aftermarket auto parts suppliers continue to exist, and will for the forseeable future. Some complete vehicles are actually sold factory-direct (usually using engines from a separate major manufacturer), so that business model can work, for special vehicles and customers. The fact that cars made by companies which no longer exist don't have dealers anymore, and those cars can be kept functioning, is proof that life is possible without the dealer - it's just more difficult. My Boler lives on without Boler dealers, but so does my Triumph.
Although I need few auto parts beyond filters (I generally drive stuff that doesn't fall apart...), I have found that dealers very often need to order in the parts anyway, so the idea of stocking brand-specific parts doesn't matter much.
As Roger said: two business models, both of which can work. I wish Escape well in their new plan.
1979 Boler B1700RGH, pulled by 2004 Toyota Sienna LE 2WD Information is good. Lack of information is not so good, but misinformation is much worse. Check facts, and apply common sense liberally.
An advertising flyer came yesterday from an RV dealer (Woody's), featuring the Escape. I checked, and they had one in the Edmonton showroom, so I went and had a look today.
I took some pictures, overall and of the parts which interest me; the Escape Trailer website has good interior shots, but I also look in cabinets and underneath. The unit in the showroom was Plan B (the one with a bathroom), with options including inside and outside showers, gaucho bunk, TV outlet, and dual propane tanks.
If people are interested, I can post pictures, likely tomorrow.
Here are the first few photos of the Escape which I saw in a dealer showroom yesterday. The more interesting ones will follow as I work my way through the raw images and render them suitable for posting.
[*]window rockguard is open; dual propane tank option visible[/list]
[*]visible features include awning and outside AC outlet (travel trailer in front and monster 5th wheel behind obscure the details)[/list]
[*]cropped at the top (shooting under that 5th wheel); battery case on end of frame; Made in BC, and yes, it's definitely at Woody's RV![/list]
[*]front front to back along the bottom, outside shower, DSI water heater, water service door, and shore power cord entry are visible (sorry, I didn't get the exposure right on the sunny side; that 5th wheel in the way again at the back)[/list](Edit on 2006 Mar 01 just formatting for readability)
Next set of photos - this time of the important bits which hold everything else up.
Tongue area
dual propane tanks inline, instead of the more common across-the-frame mounting; rectangular closed box-section frame tubing, which looks to be about 1.5" wide by 3" tall; 2", 5000lb coupler; slight double bend visible to offset coupler height above general frame height
Front section of frame under body
frame rails form A-frame tongue; body forms complete shell (one-piece lower mould includes floor); front dinette post socket visible ahead of first floor crossmember (aluminum); body appears to be held by bolts through both frame rails and (at least) front crossmember (ignore the jacks in the back, they're on another trailer)
Frame at front of axle
Step up from main section to rear section is visible (one rail height); bolt-on axle; more body bolts
Frame at rear of axle
rear frame stepped up, allowing rubber torsion axle tube to mount at height which leads to horizontal suspension arm when sitting empty; brakes and wiring visible
Placard on streetside
GVWR = 1590 kg (3500 lb)
GAWR = 1590 kg (3500 lb)
ST205-75-R14 tires, 50 PSI cold (800 kg / 1760 lb capacity at 50 PSI)
Cargo Carrying Capacity 510 kg (1122 lb), calculated with fresh water tank full (91 kg/200 lb cold plus 27 kg/59 lb hot) and waste water tanks empty
Waste tanks full 102 kg (224 lb)
... so the unloaded and dry mass is 962 kg (2116 lb), the freshwater tank is 91 L (24 USgal), the water heater is 27 L (7 USgal, supposed to be 6?), and the grey plus black tanks total 102 L (27 USgal)
"This vehicle requires a Class 3 hitch on towing vehicle" (why?)
Tongue Load Range 160kg (352 lb)
More to come from about the services (plumbing, etc) and interior, another day...
Thanks Brian.
We are Escapeowners.Our trailer is number 35, we took delivery in January 2005.
Happy campers, thats us.I can not post pictures yet so I really appreciate the work you have been doing here Brian.Our rig is set up slightly different with the propanetanks side by side.Installed an extra battery in a wider tray, also on the tongue.We are towing with Ford 150 4x4 so weight on the tongue is not a problem.We also have the bag awning, which should be good for a few years but will eventually replace it with the new Fiesta model.
Can not say enough good things about Reace and his crew.We were lucky enough to practically see our trailer being built, we realized at the time that it sure interrupted their production but we could make changes as they went along.
We are very happy with our trailer, it is perfect for us two and a Wirehaired Foxterrier (puppy).Been out for eight days down the State of Washington, home for a while to see the dentist and leaving next week for a couple of weeks on the Oregon Coast.The weather will probably be the same as Vancouver, but the scenery is different and we get to spend time in the great out of doors.Our unit is Plan B with the bathroom which is a blessing at two o'clock in the morning. We seldom use the shower since we stay mostly in State or Provincial Parks, but it is nice to have when boondocking.
Appreciate all the great information on this site and we are still learning.
Thank You people.
Allan and Raili in North Vancouver.
- Rear Streetside[*]water heater door, water fill (has pivoting cover in door to leave hose entry slot open with door closed), and power entry[*]freshwater tank drain visible under body[/list]
[*]under floor behind axle[*]drain on streetside[*]tank spans frame rails, held there by a surrounding bracket which supports the steps along the front and back (long) sides of the tank[/list]
[*]under streetside dinette bench[*]electrical panel and service cord behind[*]water pump also under bench, ahead of water heater[/list]
[*]at front of streetside[*]cable TV input beside it (see Andy's post, below) - I thought this might be the city water fitting, but a closer look at the rear service area water fill door shows a place for a hose, so that is presumably a dual hose fitting and tank fill port[/list]
[*]ahead of axle, between frame rails like freshwater[*]shower drain into front side visible[/list]
[*]greywater drain from back side of tank[*]blackwater tank straight of out above-floor-mounted black tank[*]streetside of trailer[/list]
[*]above stove[*]tank levels and battery voltage[/list]
I've corrected the cable inlet description (in my Services post), and added some tank sizes (in my Chassis post).
Still to come: eggshell details, and a demo sequence of the flexible sofa/dinette/bunks front gaucho...
Great photos! I really appreciate you posting them. I bought an Escape without ever seeing one, and still haven't as it needs some work done before I pick it up. These pictures are the best views of this brand that I have seen and are helping me understand what equipment I need to get it home and up my steep driveway.
I am looking forward to getting my trailer and taking the kids camping. Thanks again for your efforts.
[*]upper hinge shown; lower hinge similar[*]photo taken with the door swung wide open against the body[/list]
[*]two views taken with the door swung wide open against the body[*]edge of door forms deep groove to surround seal (noticeable in first view)[/list]
[attachment=1991:attachm
ent]
Door Strike and Frame Area
belly joint trim is visible, but no joint is evident in the door frame area (I don't know how)
inside of door opening is surrounded by a fiberglass frame
latch strike is mounted though weatherstrip (photography from inside is fuzzy, not the hardware)
same type of seal normally found in automotive door applications
[*]front window with cover on continuous extruded aluminum hinge[/list]
[attachment=1997:attachm
ent]
Canopy Mounting
lower and upper mounting areas for rear arm of canopy, plus inside of lower mount
inside shows plywood backing plate held in fiberglass "pocket" (focussed on wrong point, so plate is fuzzy; other wooden parts are curbside dinette bench top of sheathing material raised for photo, and solid wood brace)
Wow.....I should hire you on as a marketing consultant! I appreciate you taking the effort to provide these detailed photos to the forum. I am curious what the sales people thought while you were going about taking all these photos.
If you are interested, I have some photos of the demolding process that could accompany these photos for interest sake as to how the shells are built. If you don't mind, I would prefer to send them to you and let you post them as I don't think I could do the same job you did.
I had not posted any interior photos because the Escape Trailer website has a good set attached to the layout descriptions, but the Plan B kitchen lower cabinet is not clearly shown, so here's the only one I have...
The left (rear) lower side has a shallow cabinet in front of the fenderwell. That's the furnace on the right side.
... I am curious what the sales people thought while you were going about taking all these photos.
My usual approach to looking a vehicles in showrooms includes getting down on my hands and knees to get a good look at the important bits (suspension, etc), so I have learned to ignore strange looks from sales staff. I normally don't take pictures, but the staff didn't seem surprised at all that I was doing so. Maybe RV buyers are often eccentric...
... If you are interested, I have some photos of the demolding process that could accompany these photos for interest sake as to how the shells are built. If you don't mind, I would prefer to send them to you and let you post them..
I am certainly interested in construction images, and I think others in the forum are as well. Reace, I'll send you my direct e-mail address separately.
I was back at the RV dealer today to pick up some replacement circuit breakers for my Boler, and took a couple more photos of Escape details I missed the first time. The service doors were open on the outside shower and water fill, and here they are.
Both show the riveted mounting in these views. As Andy explained, the water fill is a nice design with a pivoting bit in the water fill door is to allow the hose to be hooked up with the hatch closed for security.
I also opened up the electrical power centre, to see the AC side (circuit breakers on the left) and DC side (fuses on the right) distribution panels.
