1974 trillium - Fiberglass RV
Old 07-18-2018, 10:46 AM   #1
Trailer: 1974 trillium
1974 trillium
My duo therm 65211-2 glen aire gravity sealed combustion wall furnace, the pilot will light for10-12 seconds, then I get a flashback and the pilot shuts off. I took the outside vent cover off and cleaned out some wasp nest and I don’t think there are any more obstructions. Any help would be appreciated. Thanks Mel.
Melvin is offline   Reply With Quote
Old 07-18-2018, 11:16 AM   #2
David Tilston's Avatar
Not sure what you mean by a flashback.
Old 07-18-2018, 11:33 AM   #3
Hello David and thank you for replying. When I try lighting the pilot and still holding the red pilot button in, it will stay lite for 10/12 seconds while holding in the red button and then a flame shoots out the pilot hole in front of the furnace and shuts off?
Old 07-18-2018, 01:47 PM   #4
I could be wrong, but it sounds like the furnace is trying to light the main burner, but does not have enough air. You may need to remove the whole furnace and clean the air intake that runs down the back of the furnace.
At this point it should be noted that the odds of successfully removing the furnace are probably less then 50/50. The outside vent is installed from the outside. There are two concentric ducts. On the inside is the exhaust tube. Surrounding that is the combustion air intake. These are supposed to telescope so that if you remove the rivets on the outside, the whole exterior vent slides out in two pieces. The trouble is that the exhaust vent get very hot, and this causes it to rust. Typically fusing the two pieces together. The outside combustion air duct will likely still slide, but since the inside exhaust part will not fit through it, (without doing some damage) the combustion air duct is stuck as well.
Some have had luck using PB Blaster and letting it soak in for some time. I currently have all of mine soaking:
PB Blaster Penetrant | Canadian Tire
You can down load the manuals for your furnace in the document center:
http://www.fiberglassrv.com/forums/d...20furnaces.pdf
trillium
1974 Trillium Trailer for Sale Mary Vander Velde Classified Archives 7 08-14-2007 07:25 AM
1974 Trillium 13' Mary S. Taylor Classified Archives 2 05-29-2006 08:25 PM
1974 Trillium Kathy Clabough Classified Archives 3 05-19-2006 10:05 AM
13' 1974 Trillium Kathy Clabough Classified Archives 2 03-10-2006 01:04 AM
1974 Trillium 13' trailer for sale Jziegler Classified Archives 4 12-15-2005 11:36 PM
