Painting Boler with Brightside marine paint - Page 2 - Fiberglass RV
Old 06-29-2013, 08:06 AM   #21
Roy in TO's Avatar
Good suggestion Bob, but not feasible in my situation. The single car length driveway to the garage slopes down from a 4 lane major city artery.
As for expense - the existing wooden mezzanine was poorly built and needs replacing as it is starting to collapse. The garage door is on it's last legs. If I have to replace those already it is not that much more to go from a 7' high to 8' door. Bonus is I won't have to pay for offsite storage and it gives me a place to work on the trailer out of the elements. Plus I won't have to swap tires/rims twice on a hill every time we use the trailer.
Do you have pictures posted of your Hunter painted?
Old 11-27-2017, 02:23 PM   #22
Trailer: Boler 1300
BC
Is theis "bikini Blue" color?
adammarktodd is offline   Reply With Quote
Old 11-27-2017, 02:39 PM   #23
Trailer: 1976 Trillium 1300
It was called medium blue.
Old 11-27-2017, 02:53 PM   #24
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Originally Posted by GMike A View Post
What would you consider an alternative that would allow it to be shined and waxed or coated? Brightside is an investment and may have to consider an alternative. I know I know but I have seen some who use Rustoleum.
I really don't know about single stage paint. Two part automotive paints (base coat/clear coat) are easy to polish, and done right, can really gleam!
Another tip for a really well covering primer (if you have a compressor and spray gun set-up) is polyester primer. You could tape a quarter to your trailer and bury it with this stuff. I'm using it this coming spring on a hot rod body I bought that needs major help. I'll prime it, then block sand it to get it smooth and straight.
Frank
2012 ParkLiner #006
Old 01-03-2018, 08:55 AM   #25
Saskatchewan
I am considering using the Rust-Oleum product do you have any pics
Tacoman7 is offline   Reply With Quote
Old 04-06-2019, 11:36 AM   #26
Joan of Shark's Avatar
Trailer: Companion
What do you use to clean the brush when painting with Brightsides Marine Enamel? I have thinner 333, but am not sure if that's the right thing to clean brush between uses.
Joan of Shark is offline   Reply With Quote
Old 04-06-2019, 12:30 PM   #27
Saskatchewan
Painting boler
I used mineral spirits (varsol) to clean brushes with
Old 04-06-2019, 12:39 PM   #28
Glenn Baglo's Avatar
Between coats, I put the brush in a Ziplock bag, squeeze the air out and put it in the fridge. Works with latex and enamel anyway.
Old 04-06-2019, 02:12 PM   #29
Trailer: Companion
Tacoman- on Interlux Brightside? Just wanting to be sure, because the specs call for their specific thinner, but I'm wondering if I can cheat a little just to clean the brushes.
Old 04-06-2019, 02:46 PM   #30
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I used varsol as well for cleaning the brushes. I just threw the rollers away and used new ones for each coat.
ststefan is offline   Reply With Quote
Old 04-06-2019, 06:51 PM   #31
FRED SMAILES's Avatar
Trailer: 13 ft Boler
I agree with replacing application equipment. I think a dried up paint brush and roller in the landfill are a lot better than all the varsol it takes to clean them.
Fred
boler, paint, painting
Painting the boler. How much paint? colin k Modifications, Alterations and Updates 15 05-18-2018 10:16 AM
Interlux Brightside Before and After lespnd Modifications, Alterations and Updates 13 10-05-2012 06:48 PM
Painting Mural, What Paint? Emily R. Problem Solving | Owners Helping Owners 7 01-24-2011 10:39 PM
Some Advice for Painting with Interlux Brightside Janine Problem Solving | Owners Helping Owners 2 08-04-2007 06:23 AM
ICI DEVOE or INTERLUX BRIGHTSIDE Paint for Boler? Suzanne P. Care and Feeding of Molded Fiberglass Trailers 16 07-13-2007 04:39 PM
