907 KG-1980 Boler weight - Fiberglass RV
Old 08-04-2015, 05:14 PM   #1
The spec sheet in my 1980 Boler says gross weight is 907 KG. The conversion chart I found states 1999.6 lbs.
Does a Boler really weigh a ton
immrbill is offline   Reply With Quote
Old 08-04-2015, 06:09 PM   #2
Ian G.'s Avatar
That is gross weight, the maximum weight fully loaded. In other words you have a 2000 lb axle capacity
Old 08-04-2015, 06:22 PM   #3
Thanks Ian. I've never owned a trailer like this before so I appreciate the input.
Old 08-05-2015, 10:10 AM   #4
Trailer: Scamp 16
Ohio
Weight
My Scamp 16 came in at 3000# on the nose just the other day at a weight station. My grey and black water tanks were full and the fresh water was empty. My camper was loaded with everything that I usually go camping with. It was not connected to the TV when weighed.
cmartin748 is offline   Reply With Quote
Old 08-09-2015, 08:48 PM   #5
Trailer: Trillium
I ran my trillium 4500 ( 15') across the scales , it was 720 kg dry weight.
caderider1 is offline   Reply With Quote
Old 08-10-2015, 05:10 AM   #6
Trailer: Scamp 16
Ohio
3000#
I think I'm still ok at 3000#, it has the 3500 lb axle. I need to recheck the tongue weight and subtract that to see what is actually on the axle.
Old 08-22-2015, 06:32 AM   #7
Gilles's Avatar
Quebec
Tongue weight with home scale.
You have the procedure to weight the hand of a caravan with a home scale?
If the weight of this one can damage the home scale, I remember that there is a procedure to be followed, to adorn this problem.
I lost this procedure, you would know how can it be done?
Thank You,
Gilles
Bigfoot 25B21RB.
Gilles is offline   Reply With Quote
boler, weight
Tongue weight or hitch weight Cathi Towing, Hitching, Axles and Running Gear 26 04-23-2012 11:38 PM
help - I am interested in buying a small, light weight trailer- total weight 2000 pdd pwedd Hi, I am.... 19 07-23-2011 12:50 AM
Tow weight vs vehicle weight Paula Bindrich Towing, Hitching, Axles and Running Gear 20 06-21-2007 08:16 PM
Tow Weight/Tongue Weight Legacy Posts Towing, Hitching, Axles and Running Gear 7 11-29-2002 08:49 PM
