adding step to Scamp - Fiberglass RV
Old 04-15-2017, 07:49 AM   #1
nancyrnfit's Avatar
Trailer: 19' Scamp Deluxe
Hello all!
I ordered the fold up step from Scamp, and am now trying to figure out how to mount it.
Has anyone done this?
Thought an attached fold up permanent step would be preferable to hauling around the plastic step we have been using.
Any advice for adding the step along with photos will be greatly appreciated!
nancyrnfit is offline   Reply With Quote
Old 04-15-2017, 09:49 AM   #2
We prefer the plastic step, as it can be placed in different positions depending on the terrain. The attached metal steps, to me, seemed to be too close to the trailer, and not as sturdy. And, they can be damaged if you drive over something high and hard.
Old 04-15-2017, 11:49 AM   #3
bullfrogeh's Avatar
I'd second this; as, while parking in a tight spot, I experienced hitting a 'hanging/folding' step on our previous RV rig, causing further damage to the TT shell itself. The portable step also becomes an easily relocated item for access to other elevated portion of your TT, perhaps for cleaning windows ?
Find yourself; and then others will find you.
bullfrogeh is offline   Reply With Quote
Old 04-15-2017, 12:43 PM   #4
Trailer: Scamp 2017 16-ft SD / FB
Scamp Step Add-On
I looked at adding a step and found that is was not worth the cost so is now use the following:
Folding Aluminum Platform Step
Manufacturer
Stromberg Carlson Products Inc Mfg Part #: PA-100
Description
Wide base design and unique double-locking safety legs make this step one of the safest on the market. Gripper strips on roomy platform and non-slip leg tips ensure that your feet stay firmly planted on the step.
Construction
Lightweight, all-aluminum provides up to 1000 lbs. of support.
Legs lock in 2 positions for 3" or 8" step height.
Platform measures 19" x 14". Folds to only 2 3/4" thick.
Silver powder-coat finish resists corrosion.
Technical Specs
Tech Specs Weight: 7.4 lbs.
Step Supports 1,000 lbs
Gattopuin64 is offline   Reply With Quote
Old 04-15-2017, 01:30 PM   #5
BC Scamper13's Avatar
Trailer: 2001 Scamp 13
Alaska
Where did you get it? Photo?
Thanks!!!
Found it on Amazon, nice that it folds!
https://www.amazon.com/Stromberg-Car.../dp/B002PWJRWS
https://images-na.ssl-images-amazon.com/images/I/41jSfP5sySL.jpg[/IMG]
BC Scamper13 is offline   Reply With Quote
Old 04-15-2017, 03:21 PM   #6
Timber Wolf's Avatar
North Florida
I have this one: Step Stool/Working Platform Bought on sale for $19.99. I cut the legs down and re-riveted the rubber feet back on. Works good and the price was right. Of course it is no problem to rework one of these, because everybody who owns an FGRV has a rivet tool and rivets right?
Old 04-15-2017, 03:26 PM   #7
sokhapkin's Avatar
SW Florida
No. I replace failing rivets with stainless steel bolt and nut.
Edit: new bolt and I reuse the same acorn nut.
Sergey
sokhapkin is offline   Reply With Quote
Old 04-16-2017, 05:13 AM   #8
Sands's Avatar
Trailer: Escape
Agree with other posts: factory steps too close to trailer body and apt to hitting stumps/rocks etc. while moving. We use a heavy plastic 'milk crate' open side down. When packing up to move crate goes in trailer open side up and is filled with wheel chocks, stabilizer feet, and tongue jack block; all the stuff that comes out first when setting up.
Sands is offline   Reply With Quote
Old 04-16-2017, 08:50 AM   #9
Trailer: 16' Standard
Ohio
Steps
Nancy
I took pictures of my factory installed steps on a 16 std.
There are additional tubes mounted to the frame to allow installation. If your trailer does not have them you will need a welder.
I added the numbers 1 thru 4 to identify them for you.
The last picture shows one of the welds that attaches the step frame to the added tubes.
The tube I marked #2 may be part of the step frame you have.
Good luck
Kenny
Kenny in Ohio is offline   Reply With Quote
Old 04-16-2017, 03:29 PM   #10
Trailer: '96 Scamp 5th Wheel
I had Larry at Little House Customs put on steps for me and have been very happy with them for several years now. Much easier to get in and out of the trailer and no hassles with moving stools around -making sure they are level etc.
JanB
The Gypsy Wagon
Janb313 is offline   Reply With Quote
Nest Caravans — Building a new FG trailer, step by step Robert Johans General Chat 569 06-30-2017 03:56 PM
Amerigo Remodel Step By Step hotrodaj31 Modifications, Alterations and Updates 11 09-11-2015 02:51 PM
Anybody add a step on a Scamp? iplumb Problem Solving | Owners Helping Owners 10 02-07-2012 07:48 AM
» Trailer Showcase
Carefree
Elfinor
Boler
ostamb
