17' burro - Page 2 - Fiberglass RV
Old 04-07-2014, 08:10 PM   #21
Carol H's Avatar
Actually the one you have is an Igloo Kool Mate 50-Quart Thermoelectric Cooler you can find a manual for it at that link. There is an optional attachment that will let it run on electrical as well as 12v.
Old 04-07-2014, 10:55 PM   #22
Trailer: in the market
Kansas
Originally Posted by Carol H View Post
Thats an igloo 12 volt portable fridge. Something like this one at Target - Often used in cars while traveling. Costco here currently has an Igloo portable 12 volt as well. It must be plugged into a 12volt circuit in some way in order to run off the battery.
I have a 7 pole round connector with 12 volt power
But what in the world could that mousetrap fan do?
I thought about putting another smaller ice chest in it
for more insulation, ice in chest with food and maybe dry ice in the
Igloo along with beer?
Igloo fan alone does what?
The one I have cools to 40 degrees?
Thermoelectric cooler? Looks like a tiny fan to me LOL
I have to see that LOL
Suki is offline   Reply With Quote
Old 04-07-2014, 11:58 PM   #23
Kansas
IGLOO Fridge
I have DC 12v connected to my Igloo cooler
in the house.
it's rated at 40 degrees cooler than outside
temperature
I have got to see this
Old 04-08-2014, 10:08 AM   #24
Carol H's Avatar
Gene a lot of people use those types of portable 12v coolers such as yours - most common to find them packing them in their cars rather than installed in a trailer though. Depending of the brand etc some say they work well, you just need to watch the power draw on the battery - check the manual link for what it eats in the way of power when on 12V - the big draw back is when you camp in temps of over 80 degrees as safe food storage is best at 40 degrees which the cooler you have can't achieve once the temps start to really rise up. You could supplement/help it in hot temps by putting a large freezer pack in it - such a milk jug full of water and frozen.
BTW the fan is moving the cold air around in the cooler. I have a small battery operated one in my 3 way RV fridge as it did not come with any fan built in (pretty common) and it does help to have the fan.
Old 04-08-2014, 04:08 PM   #25
Kansas
temperature
My thermometer read 60 degrees, I added several ice packs
to the upper tray ...Connected a 12v power supply ... fan came on
after an hr it read 84 degrees took thermometer out it fell to about
70 degrees on my work bench.
This Igloo will not cool anything.
Old 04-08-2014, 04:26 PM   #26
David Tilston's Avatar
Actually, they either cool, or heat, depending on the polarity of your 12 VDC. I suspect that yours is in the heat mode.
It should be noted that they are power hogs. Best to get a real fridge. What are the dimensions of the hole it is in. Please include the depth to the first obstruction.
Old 04-08-2014, 06:03 PM   #27
Carol H's Avatar
Even the 3 way fridge in my trailer takes several hours to cool down.
The manual for your cooler says when you plug it in at the cooler you need to align the C on the receptacle beside the dot in order for it to cool.
Old 04-08-2014, 06:28 PM   #28
Kansas
Switch Polarity
What is a real fridge? The mega dollar?
I switched Polarity
Fridge 23" D ....20 1/2" H..21" W Fan is mounted on the left front side
Hole is 23"D to first obstruction ....22" H...21" W
I have not tried this cooler while traveling just bought the Burro camper
Testing on my work bench
I put another ice pack in and will wait and see
Looking at it I never dreamed it could cool
I have a 7 round connector and it feeds off my batt while I'm traveling.
Thanks, Gene
Old 04-08-2014, 06:38 PM   #29
Kansas
Receptacle is align right but I may have had reverse polarity
Thanks for the link for manual
Gene
burro
Burro Widebody, Burro and UHaul Nancy Reeves Problem Solving | Owners Helping Owners 17 11-25-2023 12:51 PM
Project Burro- 1978 Burro 13 foot Scott B. Classified Archives 0 08-09-2009 11:19 PM
I've got a Burro Manual and Burro Waxing Tips!! Amy P Problem Solving | Owners Helping Owners 9 07-28-2009 08:20 AM
