Scamp water heater bypass questions - Fiberglass RV
Old 11-21-2018, 07:08 PM   #1
Trailer: Scamp 13 Layout B
I just finished the annual winterization ritual. I had a water heater bypass kit installed last spring and I'm wondering: 1) was it installed properly and should there be a shut off valve installed on the heater's inlet line; 2) do I have the valves set properly; and 3) is this why I now have hot water coming out of cold water taps? The vertical picture shows the bypass kit -- the city water connection is at the top. The horizontal pic shows the valves set for winterization (correctly I hope).
Name:	water heater verticle.jpg
Name:	water heater horizontal.jpg
sweendog is offline   Reply With Quote
Old 11-21-2018, 08:23 PM   #2
Most bypass kits use 2, 3 way valves. In your situation you need a cold water shutoff valve between the cold water input of the water heater and your cold water line T. The hot and cold valves needs to be closed and the cross over valve should be open for bypass operation. Make sure there is no pressure on the system before removing your WH drain plug. If you close your hot and cold valves with pressure on the system the WH will be pressurized even though your lines are not pressurized.
Eddie
Old 11-22-2018, 12:32 PM   #3
Thanks Eddie - I appreciate your help. Looks like I still have some work to do.
water heater bypass Peer n Brandee KL Care and Feeding of Molded Fiberglass Trailers 3 07-17-2018 07:04 AM
Leave Water Heater on Bypass? Connie Estep Plumbing | Systems and Fixtures 12 07-31-2017 11:04 AM
Water heater bypass Chris Z Plumbing | Systems and Fixtures 24 07-15-2016 08:01 PM
Camco 35953 water heater bypass kit ThomasE Modifications, Alterations and Updates 11 08-27-2015 07:16 AM
Where do I find the water bypass switch? Karalyn Plumbing | Systems and Fixtures 9 10-19-2006 01:30 PM
» Trailer Showcase
TBD
Andi
1979 Biggar
Mak
