Replacing scamp door seal - Fiberglass RV
Old 04-26-2015, 06:57 PM   #1
Trailer: '07 Scamp 16' SD
Wisconsin
Evening all, I'm working on replacing my scamp door seal with the new style seal, and I was wondering how scamp is handling the bottom of the door now, specifically the corners. The old foam just goes over the top of the trim in the corners, which doesn't seem like it'll work with new rubber seal.
Can someone with the newer style seal let me know how they are set up, or if you've replaced it already, let me know what you did.
As always, thanks in advance
Paul
glennco is offline   Reply With Quote
Old 04-27-2015, 06:53 PM   #2
Wisconsin
Any ideas on this one, hoping someone with a newer scamp, or someone who has replaced the seal could give me some insight.
Paul
Old 04-27-2015, 07:33 PM   #3
rdickens's Avatar
Trailer: 2017 Scamp 16 Deluxe
Missouri
Removed old foam seal (using much effort plus WD-40, brake cleaner, alcohol, Goo Gone, etc.)
Installed new gasket up one side, over the top, and down the other side (with the flange out) right up next to the white door trim. Will do bottom fairly soon now.
Seal is very good. So far, door is a little harder to pull completely closed against new seal. Bottom of side near door hinges came loose once and had to reattach with automotive trim cement (or gasket adhesive?)
Hopefully, others may provide better explanations.
Good luck!
Ray
Sent from my SCH-I545 using Fiberglass RV mobile app
rdickens is offline   Reply With Quote
Old 04-27-2015, 08:41 PM   #4
floyd's Avatar
I love the new seal, but I recommend using square solid closed cell foam for the threshold.
Old 04-27-2015, 09:55 PM   #5
Trailer: 1985 BigFoot G
Mississippi
Are you guys talking about the outside door? I don't think mine even has a seal. It's a Bigfoot 1985. I guess I need to see IF it's suppose to have a seal on it. This poor trailer hasn't had any TLC in awhile I don't think.
Gardnpondr is offline   Reply With Quote
Old 04-28-2015, 09:21 AM   #6
rdickens's Avatar
Missouri
It is an outside door seal supplied for Scamp trailers.
Ray
Old 04-28-2015, 05:38 PM   #7
Trailer: Scamp 13
Below is a picture on how I did it. I don't know if it is right or wrong but it seems to work and I am happy with it. Note that I had 1 seal all the way around except on the bottom I had two seals. I forgot how to rotate the picture. Sorry.
Eric
ericw is offline   Reply With Quote
Old 04-29-2015, 07:05 PM   #8
Wisconsin
This is a perfect picture, thank you much.
Both the closed cell foam and double seals are a good idea.
Interesting that you didn't go over the trim piece. The old original foam did go over the trim piece, and I was wondering how people were handling that.
Thanks for all the help so far.
Old 05-04-2015, 09:07 PM   #9
Wisconsin
I completed the install of the new door seal. It looks phenomenal in comparison to the old foam seal, and it is definitely harder to close. I'll try to post a few pics tomorrow.
We'll see after we get out there and use it some, but it's definitely a worthwhile upgrade.
Old 05-05-2015, 05:37 PM   #10
Bill Nolen's Avatar
Trailer: Had Scamp 13'.
Oklahoma
Eric
Attachment 83269
Is the seal attached to the door or the door jam?
Bill
Bill Nolen is offline   Reply With Quote
Old 05-05-2015, 05:51 PM   #11
Trailer: Scamp 13
Bill
The seal is attached to the door jam/trailer.
Old 05-05-2015, 07:51 PM   #12
Bill Nolen's Avatar
Oklahoma
Thank you!
Bill
Scamp Door Seal ericw Modifications, Alterations and Updates 13 11-09-2020 06:00 PM
window on scamp door seal help needed PLEASE Red Fox Care and Feeding of Molded Fiberglass Trailers 1 06-10-2014 04:27 AM
Replacing window seal in Scamp Nick Glenney Problem Solving | Owners Helping Owners 20 06-09-2014 11:13 PM
door on `98 scamp won't seal fusedlight Problem Solving | Owners Helping Owners 12 07-15-2013 08:33 AM
Scamp Door Seal Parker Buckley Problem Solving | Owners Helping Owners 16 10-11-2011 09:55 AM
