LED taillight conversion for Boler - Fiberglass RV
Old 06-23-2016, 04:34 PM   #1
Name: Chris & Sarah
Manitoba
We bought the 4" LED round taillights from Princess Auto. They fit perfectly into the red taillight cover but we've run into a problem trying to reattach it to the Boler - on the back of the LED there is a protrusion.
For others who have installed this light, did you cut a small hole in the Boler taillight area? Or is there some sort of mounting collar to accommodate that protrusion?
Many thanks,
Sarah
ChriSarah is offline   Reply With Quote
Old 06-23-2016, 04:42 PM   #2
Trailer: Boler13/trillium4500/buro13
Many thanks,
Sarah
Those are not the lights I would use as princess auto carries a little larger led which is a better fit on the boler . They are on sale usually every couple of months but are not right now .they will also not require you to make a big hole.
Mikmay is offline   Reply With Quote
Old 06-23-2016, 05:17 PM   #3
Name: Chris & Sarah
Manitoba
Yeah, but I was going based on this site's recommendations: Boler Parts - Boler-Camping
This guy said he used the 4"one, so that's what I bought...
Ugh. We're about 2.5 hr. away from Princess Auto...
Old 06-23-2016, 07:27 PM   #4
If you look at the site you posted you'll see the third picture down with th e 7 in lights , those are the perfect fit for a boler .The lights you have will work but in mho they will not look as good
Old 06-23-2016, 08:51 PM   #5
jkmboler's Avatar
Trailer: 1974 1300 Boler
Manitoba
If you want to use your original taillight lenses, with a LED assembly inside, you will need to use the 4" ones. The 7" units will not fit inside your original lenses.
You should have no problem if you cut a hole to allow for clearance with the 4" units. Just make sure to seal the hole, butyl tape would probably be best.
I would consider cutting a 4" hole and mounting the 4" LEDs flush, then fit the original lens over top.
1974 Boler 1300
Manufactured in Winnipeg, Manitoba.
jkmboler is offline   Reply With Quote
Old 06-23-2016, 09:12 PM   #6
Yes I would agree with Kent if that was your intent to install them inside your original lense.
Old 06-24-2016, 05:14 PM   #7
One thing with LED's is will your RED led's shine enough through your RED lenses.
Call the store, speak to the manager and see if you can exchange what you have by mail saving the long drive!
Joe
Old 06-25-2016, 09:36 PM   #8
jkmboler's Avatar
Manitoba
Originally Posted by Joe Romas View Post
One thing with LED's is will your RED led's shine enough through your RED lenses. Joe
There is no problem with red LEDs shining through a red lens.
They will be much, much more visible than the original incandescent bulb!
1974 Boler 1300
Old 06-26-2016, 07:50 AM   #9
Ian G.'s Avatar
Many thanks,
Sarah
Hi Sarah, you used my information and it works great, you bought the correct 4" lights and will not have any troubles. These provide and extremely bright light through the existing "wedding cake" lens and look far better on a boler that the bus lights in my opinion.
Mount the 4" lights inside the lens like you have shown, you will need to cut a small square in the body behind the lens for the modular plug to fit. Use butyl tape to seal around the original lens flange to seal it to the body. Don't tighten the lens screws too tight ofr you can crack the lens.
Old 06-26-2016, 08:45 AM   #10
Roy in TO's Avatar
Would it not be possible to cut the small square off the light and rewire?
Old 06-26-2016, 09:30 AM   #11
Ian G.'s Avatar
The terminals on the back of the light connect directly to the circuit board so you cannot cut it off, the construction of the 4" lens is also sealed against water, cutting the terminal area would allow moisture to enter inside the lens and electronics
boler, light
LED light conversion Boler shan.mcc Electrical | Charging, Systems, Solar and Generators 28 06-29-2015 10:25 AM
LED taillight conversion - Cheap! redbarron55 Modifications, Alterations and Updates 2 04-06-2015 10:26 AM
Wedding cake tail lights conversion to LED JDNikirk Modifications, Alterations and Updates 3 11-25-2012 05:56 PM
LED taillight bulbs Alistair Camelford General Chat 9 11-10-2006 01:39 PM
