Solar system for 78 surfside - Fiberglass RV
Old 09-03-2018, 09:23 PM   #1
Trailer: Triple e surfside
BC
Lightbulb Solar system for 78 surfside
Hi everyone,
- So I am looking to buy a 80W solar panel kit and was wondering if I can run the solar panel to a charge controller to the battery which runs to my 110/12V converter, which then runs lights/sockets/fridge ?
- Or do I need to install an inverter?
- As far as I know my stock converter is only a converter and not a charger/converter.
Dwalk_21 is offline   Reply With Quote
Old 09-04-2018, 04:30 AM   #2
Yes you need an inverter to get 120 volts alternating current from a 12 volt direct current battery.
The solar cant hurt but you should do some math. I think you will find not only is there no free lunch, when it comes to this plan, there is no cheap lunch either.
80 watt panel means maybe 5 (or so) amps charging at best. Optimistically figure ten hours of good sun, thats 50 amp-hours (give or take). Cloudy days mean less, maybe none.
Fridge uses maybe 120 watts, thats 1 amp at 120 AC and 10 amps at 12 volts. Optimistically figure 85% efficiency for the inverter, you need almost 12 amps of 12 VDC to use the fridge with an inverter. Running fridge for 24 hours is 282 amp hours.. a bit more than the 50 you got from the solar if you were lucky. Outlets.. that depends on what you want to use them for. Many things (like cell phone chargers) have 12 volt DC options and that works better with a 12 volt battery than using an inverter to go one way then the cell phone charger to go back to low voltage. Lights are normally 12 volt anyway, and LEDs will sip power.
And we have not even mentioned the battery (or batteries) needed.
I'm not saying that you cant use an inverter, only that you should do some through planning and run some calculations before spending money.
solar, surfside
Bigfoot Solar System Tim D. Modifications, Alterations and Updates 29 08-04-2020 01:44 PM
New battery- what type for future solar system? LizP Problem Solving | Owners Helping Owners 15 02-26-2009 06:30 AM
75 SurfSide goes for propane system check Scott S. Modifications, Alterations and Updates 5 06-26-2008 07:12 AM
can you mix solar system brands? Nancy H Electrical | Charging, Systems, Solar and Generators 2 06-15-2006 07:47 PM
Solar System Advice Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 05-13-2003 10:03 PM
