Cutting a Bigfoot 25B175FB to install a weight distribution hitch? - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Towing, Hitching, Axles and Running Gear
Old 09-01-2017, 08:12 PM   #1
Hi All,
I alluded to this in another post, but I very recently purchased a 2016 Bigfoot 25B175FB trailer and am researching installing a weight distribution hitch in order to alleviate some fishtailing which was experienced.
My local RV shop wanted to install an Anderson Hitch, although they said they would need to cut into the fiberglass shrouding surrounding the propane tanks in order to install the brackets. I am very hesitant to cut into the fiberglass of my new trailer, and was wondering if any other Bigfoot owners could let me know if there is a hitch/adapter that one could use in order to get weight distribution on the Bigfoot without cutting into the trailer.
I also sent an email to Bigfoot and am awaiting a reply.
Ryan
rdf0011 is offline   Reply With Quote
Old 09-01-2017, 08:23 PM   #2
Jim Bennett's Avatar
If you have fishtailing, the cause of that should be dealt with before any WDH is installed. If it's usually caused by improper loading and needing more hitch weight.
Not sure what WDH would clear your front cover though.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-01-2017, 08:32 PM   #3
+10 to Jim's comment. Get an accurate tongue weight, and a trailer weight of your trailer loaded for camping.
Old 09-01-2017, 08:50 PM   #4
live with it....
if you want a WDH...you're going to have to live with cut-outs in the FG....that's just the way it is...doesn't affect anything with the cover...it's only secured by three fasteners...the cut-outs are in the middle of the run....
Looking at your rig, you may or may not need a WDH....it's all about the rear suspension of your TV.....if you can put 400 lbs right at the rear of that trucks bed and not affect the ride, you don't need one....most people do....makes for a nicer drive as well....
a regular/simple/old school WDH has no effect on sway whatsoever....that's not why you use one...and really, when you think of it, there would not be any point in having one if you didn't have enough tonge weight to collapse your rear suspension to begin with
Old 09-01-2017, 08:52 PM   #5
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
I agree too.
Measure the weight of the trailer and the tongue weight with it equipped just as it was when you had the problem.
For stability, don't have any heavy equipment hanging on the rear of the trailer. Make sure your truck tires are heavy duty and inflated properly.
Sounds like, if anything, you need sway control and not necessarily a WDH. Before you buy an Anderson, look on the Oliver forums and learn more about their problems.
Raspy is online now   Reply With Quote
Old 09-01-2017, 09:40 PM   #6
Borrego Dave's Avatar
Ryan, as you've found out the TW was a bit light do a few tests before you invest in a WDH. Load it like you're going camping and put some heavier things forward and go pull it on the road. You may find that that was the problem. BTW, cutting the FG for the WDH is a non issue for concern.
Old 09-02-2017, 05:20 AM   #7
CindyL's Avatar
Trailer: 16 ft U-Haul VT
You could also join the bigfoot groups on Facebook and ask your questions or Bigfootowners Club. We had to cut a bit out for our Propride as you can see in the images.
CindyL
1988 Bigfoot Silver Cloud, "The Egg Carton"
Old 09-02-2017, 08:54 AM   #8
Trailer: Bigfoot 30th Anv. 25B25FB
Minimal cutting with an E-Qualizer brand hitch.
Wacenturion is offline   Reply With Quote
Old 09-02-2017, 11:53 AM   #9
Trailer: Trail lite by R-VISION
Check Trailer Tire Pressure with a gauge, I had a older 2 Axel Trailer If one tire was 5 pounds lower than the rest it was ok until 50 MPH then it waged like a dogs tail.
I now check all tires dailey.
JMCK is offline   Reply With Quote
Old 09-02-2017, 12:24 PM   #10
Trailer: noneofyourbusiness
x2 on the e-qualizer hitch
We use one on our 25b175G. Towing is solid as a rock. Very pleased with it. We use an "e2 Round Bar Weight Distribution with Sway Control".
But you will have to have some small cut outs in the propane fiberglass cover made.
Ritchie
Bigfoot 25B175G 2008 Anniversary Edition
FRL001 is offline   Reply With Quote
Old 09-02-2017, 01:03 PM   #11
madjack's Avatar
Trailer: 2015 Casita 17FD
Rapides Parish La.
...fishtailing can be traced (90+%) to faulty loading of trailer...too much weight to the rear of camper is the culprit...towing with the tongue up instead of dead level or slightly nose down can cause this problem as can improperly inflated trailer tires...a wdh or anti-sway WILL NOT FIX this problem...at best, it will mask the problem untill some other factor causes the fishtailing to rear it's ugly head with possibly catastrophic consequences...find and fix your actual problem first!!!!!
madjack
madjack is offline   Reply With Quote
Old 09-02-2017, 01:11 PM   #12
looks good....
that e2 hitch looks good....and the amount of FG to cut out would be quite a bit less than a chain type (that uses chains and levers like mine)....not bad price wise either....
the anti-sway stuff ??? hummm, I guess I can imagine SOME resistance.....would be interesting to see an objective test.... and wouldn't metal on metal get noisy after a while???
maybe I'm just being picky..........but if I needed one I'd have to have a hard look at it....in person!
good thread!
Old 09-02-2017, 01:24 PM   #13
https://www.equalizerhitch.com/
https://www.equalizerhitch.com/how-equalizer-works
bigfoot, weight
is my weight distribution hitch worth the tongue weight and effort. beachcamper54 Towing, Hitching, Axles and Running Gear 24 01-25-2014 12:41 PM
bigfoot weight distribution hitch Melissa in Oregon General Chat 20 12-04-2013 02:20 PM
Weight Distribution Trailer Hitch Systems John D. Problem Solving | Owners Helping Owners 1 01-10-2006 04:53 PM
