2014 Outback and Scamp13 specs - Fiberglass RV
Old 09-16-2014, 09:52 PM   #1
Trailer: Scamp 13 ft
I have learned a lot from many regular posters here and decided to document my Scamps hitch information so it may help others. I have illustrated the setup as well as the general tongue and trailer weights for my particular trailer but may help others with similar setups. I have added several customs to this 13', most of which are in my profile album.
We just returned from Jasper Alberta, 2000 miles from Seattle and back. 26 degrees at night and snow, would not have asked for less. It was great and we were warm at night with about half the time finding electricity at campsites. 6 Hotsprings in 10 days helped a lot too. We take our Scamp up there every few years, lots of hills, trailer brakes work great and a must have in places.
Shawn
shawn bertagnole is offline   Reply With Quote
Old 09-17-2014, 06:06 AM   #2
TomK's Avatar
Trailer: Scamp 16
Shawn, that's an impressive diagram. You obviously spent quite a bit of time on it. I hope it helps some folks think about some of the things you need to take into consideration when setting up your rig for towing.
We have a 6 week old 2014 Scamp 13 Std, and our tug is a 2011 Subaru Forester. I called Scamp before we went to pick up our trailer in order to get the correct ball height. I was told the top of the ball should ideally be about 16" when the trailer was hooked up. For our car, I stood on the ball, and my wife measured the distance from the top of the ball to the ground. This simulated the 200 lb. tongue weight.
I already owned a 2" drop / 3/4" rise ball mount for our Curt class III hitch. In order to get the 16" height, I had to use a 2" high rise ball. 2" Hitch Ball - 2" Rise - 1" Diameter x 2-1/8" Long Shank - 6,000 lbs Curt Balls C40034
I never heard of them before. Bottom line, it worked out great. We have no sway problems at any towing speed, and the trailer is perfectly level when hooked up.
I'm wondering why your trailer ball is 2" lower than ours? Is your trailer level when hooked up? We have similar options. I tried to configure ours to keep the tongue weight to below 200 lbs. We have A/C, but that weight is over the axle, so not a factor. Did Scamp raise the frames as well as the ceiling after the 2006 fire? Maybe your axle has the normal sag due to age? Just curious.
Tom
TomK is offline   Reply With Quote
Old 09-17-2014, 06:08 AM   #3
MC1
MC1's Avatar
Looks good Shawn.
Suggestion..... one common mod in these parts is to get the ball mount shank redrilled which moves the ball as close to the back of the car as possible. This decreases the overhang to wheelbase ratio which improves overall towing stability.
as shown.....
MC1 is offline   Reply With Quote
Old 09-17-2014, 06:27 AM   #4
TomK's Avatar
Trailer: Scamp 16
On our trip home from Backus, I was struck by how level the trailer was when seen from a distance and snapped this picture.
Old 09-17-2014, 06:38 AM   #5
MC1
MC1's Avatar
Tom, very level. Doesn't get any better than that!
Old 09-17-2014, 07:09 AM   #6
TomK's Avatar
Trailer: Scamp 16
Originally Posted by MC1 View Post
Looks good Shawn.
as shown.....
Wow W, that is one heavy duty looking hitch! Is that for your Airstream? I guess I'm so used to looking at the Scamp set-up. You're obviously better at backing up than I am. My Forester backs up in 2" increments. I'm afraid your set-up would really do a job on the bumper when hitching up.
I could probably get my mount about 2" shorter, but I wouldn't be able to open the hatchback. It clears the tongue jack by about 1" when parked on level ground.
Tom
Old 09-17-2014, 07:21 AM   #7
MC1
MC1's Avatar
For sure Tom backing up is interesting. I had to mount a mirror on the crank arm to watch the backing up process. It works good. "better than having the BH help" LOL!
Yes, for the Airstream. It is a 40 year old Reese dual cam with 750lb bars.
Old 09-17-2014, 08:47 AM   #8
Yes, I think it is sagging a little. I am the second owner and am unsure how they stored it. I always keep it on jacks now.
Old 09-17-2014, 09:33 AM   #9
honda03842's Avatar
Name: Norm and Ginny
Trailer: Scamp 16
Copying
Looks good Shawn.
as shown.....
We drilled the shank on our CRV and now use it on the Odyssey. It improves things the order of 5% and for the addition of one hole is one of the easiest improvements and is free.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
2014 Jeep Cherokee Specs MC1 Towing, Hitching, Axles and Running Gear 0 04-17-2014 03:00 PM
Drain hose (sink) specs and availability? Darrell O Plumbing | Systems and Fixtures 3 09-07-2012 07:10 PM
Scamp13 signal and brake light issues R Drayer Problem Solving | Owners Helping Owners 10 04-15-2012 07:26 AM
Update on Scamp13 and Forester maiden Voyage bcomnes General Chat 2 04-29-2010 07:24 PM
Which U-Haul brake controller for Scamp13 pulled by a Forester?? bcomnes Towing, Hitching, Axles and Running Gear 1 12-23-2009 10:44 PM
