Regardless what the anticipator is set at, the
furnace should come on normally. You can jumper it also. If I remember right the sequence should be something like this. Set point is reached, turn thermostat all the way up, the fan should come on to purge leftover gas fumes in the heater, glow igniter should glow red and then gas should come on. Good luck
