Door hinge bolt size - Fiberglass RV
Old 04-22-2015, 11:01 AM   #1
kip
Name: Kip, 1978 boler 1300
Trailer: boler
Door hinge bolt size 1978 boler 1300
Quick question hopefully someone knows. What is the size of the bolts on the door hinge for a 1978 boler 1300? (The bolts that hold the hinge to the frame)
kip is offline   Reply With Quote
Old 06-30-2016, 02:04 PM   #2
Trailer: boler
same question
I've asked the same question but if I figure it out before someone responds to my post I'll pass on the info.
Cheech00TS is offline   Reply With Quote
Old 06-30-2016, 02:16 PM   #3
Ian G.'s Avatar
The bolts are 1/4"-20 also know as 1/4"NC
Length I believe is 3/4"
I highly recommend you use anti seize compound on the threads when you reassemble. On the door bolts try to find the flattest or thinnest head available.
P.S. I sell the stainless steel hinge rebuild kits
Old 06-30-2016, 02:44 PM   #4
Trailer: boler
Boler hinge bolt dimensions
I was just about to share this for you! Thanks
boler
Trillium 4500 frame bolt size type Fred G. Problem Solving | Owners Helping Owners 5 10-29-2013 05:19 PM
Broken bolt stuck in Boler hinge bomni Problem Solving | Owners Helping Owners 18 04-26-2012 11:12 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
boler door hinge pins Ben, Vanden Berg Problem Solving | Owners Helping Owners 9 07-23-2009 12:25 PM
Exterior Door Hinge Replacements THETFORD sewer ROBERT ONEILL Problem Solving | Owners Helping Owners 2 05-18-2009 06:12 PM
