Originally Posted by Mollie
I want to purchase a good single deep cycle battery with an inverter and wondered if I could get some suggestions of which ones? We would use this for 2-5 day trips for single lights and charging phones, etc when dry camping. Canadian tire has has batteries and inverters but the inverters have several different watts.im thinking 1000 watt inverter is enough correct? And the batteries seem to only go up to roughly 200 minutes of use? Solar panels I would assume are an option?
: a single batter and a 1000W inverter will only last u one day but if you were to install at least a 50A
solar panel that would keep your
battery charged, we run 2X12V batteries with a 1000W inverter and they last us 3 full days, then we need to either run the engine or
Generator to recharge, we use for 2 laptops, charging of Camera Batteries, Laptop Batteries, phone battery, Hot Spot for steady Internet service. We do not yet have a
solar panel but where thinking a 150W unit will work just fine for us to keep our batteries charged and no noise for neighbours.
We only run our rooftop when we are plugged in otherwise it is the fantastic fan and a open window especially at night when cooling off so we can sleep.
We hardly stay much longer than 3 days anywhere as we travel all the time, share the driving while I still can though yesterday it was 300 miles in a Suzuki X90 2 seater with no AC and it was around 95*F but air movement helps if one is sweating as it cools u off.
Hard part for us to put a
solar panel on roof is it is FG roof and I hater more holes than we need up there but so far no
leaks. after bout 6 weeks on road things get pretty tight especially when buying junk along the way.
So good luck with what you do, get rid of the 12V stuff and live with your 2 burner stove, if not comfortable build a
light metal wall around it, if you have 1" gap it will stay cool in the gap same for wood stove in cabin, as sometimes one cannot get the right distance from wood wall so the 1" gap helps keep the log walls from heating up to the point of burning.
Stude
