Want an awning for my Surfside and don't know where to look? - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Care and Feeding of Molded Fiberglass Trailers
Old 06-02-2010, 10:11 AM   #1
Trailer: 1976 Surfside TM14
Thumbs up
Hello,
Would like to buy an awning for my 1976 Surfside under construction. If anyone knows where to buy them , I would appreciate the info. When I try to google it, I just seem to get sites that are for larger Rv's. I have seen awnings on Bolers, and other small trailers so I know they must be available somewhere. Thank you for the help. Kathy Provost
Kathy Provost is offline   Reply With Quote
Old 06-03-2010, 04:52 PM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
try somewhere like camping world, you would most likely be looking for a " bag awning"
Joe
Old 06-03-2010, 06:08 PM   #3
Trailer: 1980 Trillium 13 ft
Try this company.
http://www.interwestsports.com/bag%20awnings.html
Peter J Halsted is offline   Reply With Quote
Old 06-03-2010, 07:02 PM   #4
Pat C's Avatar
Trailer: 1981 Boler 13 ft / 2005 Dodge Caravan
Hello,
We got the awning for our Boler from Interwest Sports.It was shipped USPS to us in Ontario within a week of ordering.The cost with shipping was only $214.00.We have a seven foot but you would probably want a longer one at least eight ft.We love our bag awning.Its very easy to set up and a screen enclosure can be purchased to fit the awning.
Pat C is offline   Reply With Quote
Old 06-06-2010, 09:36 PM   #5
Thank you very much! That is exactly what i was looking for! Much appreciated!
Old 06-07-2010, 09:24 PM   #6
james kent's Avatar
Trailer: Boler 1984
Vintage Trailer Supply sells some very much like the originals.
Old 06-17-2010, 07:13 AM   #7
Trailer: Casita Patriot
i've found one for my casita at a vw bus parts place. http://www.busdepot.com/index2.jsp
it's an 8" lightweight awning made to fit a vw camper bus. the awning along with the optional suction cup adapters works great on my 13' for less than $200.
p
patrick crawford is offline   Reply With Quote
Old 06-17-2010, 12:13 PM   #8
Alistair Camelford's Avatar
Trailer: Trillium 13 ft 1973
Just a "consumer report" on the intrawest - supplied bag awning. After one three month stint in Florida, one vertical arm became almost impossible to deploy to full height. When I got home I disassembled it and found corrosion and a metal flash on the locking piece. There was a groove on the aluminum lower arm from the flash on the steel insert . Taking it apart to buff and lube the offending plate involved drilling out the 1" rivet. None are available locally and the manufacturer does not return my emails. Also corroded was the detent/spring-loaded button on the one rafter arm. The bag covering fills with rainwater due to the height of the "C" tube on the side of the Trillium (had to raise it to be able to open/close trailer door)...so i have poked drainage holes in the bottom of the bag.
That being said, the awning does the job...but I am not impressed with the quality and response to customer complaint.
"Caveat Emptor", fellow eggers
Alistair & Inge in the Road Toad
Alistair Camelford is offline   Reply With Quote
Old 06-17-2010, 01:15 PM   #9
Alf S.'s Avatar
Send a message via Yahoo to Alf S.
Hi: All...I would certainly buy the rope& pole awning from Vintage Trailer Supply. They are made out of Sunbrella type fabric and made to be period exact for a vintage trailer...they arn't cheap but look great. The smallest sized one will work on a 13' trailer. VTS
Alf S. is offline   Reply With Quote
Old 06-17-2010, 04:23 PM   #10
Marinab's Avatar
Trailer: 1977 TM14 Surfside / 2007 Toyota Tundra V8 2wd
Arrow
I'm getting rid of my awning. I found it too hard for one short person to put it on, especially in the rain! What is a fair price for a used one? It's gold and white stripes with a fringe all around. No rips, in very good condition. Probably because it's hardly been used.
Life would be a million times better if there were Pinatas strategically placed throughout the day.
Marinab is offline   Reply With Quote
Old 07-02-2010, 06:21 PM   #11
Paul Richter's Avatar
Trailer: Trillium 1971 13 ft
Alistair, I was just wondering if you have the classic or the supreme awning??
Paul "The Nascar Rig"
https://community.webshots.com/user/p...host=community
Paul Richter is offline   Reply With Quote
Old 07-03-2010, 09:34 AM   #12
Paul, I bought the Supreme...the one with square tubing and the rafter tensioning device. Like I said in the posting, it is "OK"...does the job...but in a seashore environment you will get corrosion between the dissimilar metals used in the manufacture and the water that stays in the rolled up unit. Just spray lots of silicone or "Jigaloo" on the telescoping parts.
Cheers...Alistair in the Road Toad
Old 07-11-2010, 09:28 AM   #13
Hi there Alistair, I'm thinking of getting the supreme awning. I was just wondering what size of rivet did you use to attach the rail to the trailer??
surfside
adding Awning rail and awning to Surfside ericmarlo Problem Solving | Owners Helping Owners 7 04-27-2022 06:45 AM
Bag Awning vs. Regular Awning Pamela S. Problem Solving | Owners Helping Owners 7 02-22-2020 06:20 AM
Surfside builder?Surfside manual Hub Bru Problem Solving | Owners Helping Owners 19 06-19-2015 11:03 AM
Awning for 1977 Surfside Triple E njrucker Care and Feeding of Molded Fiberglass Trailers 7 04-14-2009 04:57 PM
Surfside awning and or add a room ? ericmarlo Classified Archives 0 07-05-2007 10:54 PM
