12-09-2014, 08:39 PM
Trailer: 17 boler
boler propane lines
I was thinking of using flexible rubber hose (propane hose) instead of copper inside the trailer. has anyone ever used it? is it safe, up to code?
i can't use copper to take the sharp corners without creasing
any thoughts?
thanks
12-09-2014, 09:10 PM
Splice in 45 degree or 90 degree elbows.
Dave & Paula
12-09-2014, 09:15 PM
There are fairly cheap automotive tools for bending copper and steel tubing.
12-09-2014, 09:26 PM
Dave & Paula
Yes, and use a flaring tool on the copper lines. It's not a good idea to use ferrule fittings.
12-11-2014, 12:10 PM
Trailer: prolite
Nova Scotia
copper fitting
In Canada I believe or should say it's not allowed to use compression fittings for fuel lines for hookup to a furnace, so would imagine it would be the same for a RV
12-11-2014, 12:44 PM
I did residential propane installation for heat and hot water years ago. Flare fittings only, and we used a heavier flare nut referred to as a "frost nut". A search here will bring up previous discussions on this subject. For under a trailer iron pipe is recommended.
12-11-2014, 02:17 PM
They do make a copper propane tubing that is covered with an outer protective skin for direct bury. Contact your propane gas company and discuss it with them.
12-11-2014, 02:18 PM
Trailer: Scamp 13
any thoughts?
thanks
Per National fire code here in the US you can't use rubber hose inside. If using copper you need to use double or single flair fittings. I would check the code in Canada since you live there.
12-11-2014, 09:39 PM
Trailer: 17 boler
i will go with copper. i bought a bender for the tight corners.
thank you for the info
12-20-2014, 07:51 AM
Name: Borden and Carole
Had to do some work and was told no fittings inside trailer except to connection at the fridge stove or water heater, all splits outside under floor? Also some sort of paste/tape for the threads. I am not a gas fitter but did not argue with someone who was.
Our postage stamp in heaven.
12-20-2014, 07:54 AM
any thoughts?
thanks
They have a pipe bender that will do a 1" curve and a spring looking pipe bender that work well have both but spring type need to match size of pipe.
